Anti-Seize where and when to use it
Discussion in 'The Hokey Ass Message Board' started by daveyboy56, Dec 29, 2007.
  1. daveyboy56
    daveyboy56
    Ok tell me about anti-seize the do's and don'ts
    thanks Dave
  2. Unkl Ian
    Unkl Ian
    High Temp Anti-Sieze works real well on exhaust pipes.
    Stops them from rusting together.
  3. garvinzoom
    garvinzoom
    I always use it when working with stainless or aluminum. I use it on lug nuts but never get it on the shoulder that goes against the wheel.
  4. Prop Strike
    Prop Strike
    I use it on...
    the back of disc brake pads -- prevents squeaks
    wheel stud threads
    exhaust bolts, studs, nuts, etc
    any place two parts prone to galling are torqued (the lug nuts on your 911 wheel for example)
    spark plugs in an aluminum head (well away from end, very little)
    A little bit of anti-seize goes a long way.
  5. garvinzoom
    garvinzoom
    I always put some on my brake rotors also, where it seats up against the hub so you can get them off without the use of a BFH.
  6. tfeverfred
    tfeverfred
    Nut and bolts, especially chrome nuts and bolts.
  7. Ole don
    Ole don
    Lug nutz, spark plug threads in an aluminum head, any ch***is parts, all stainless parts.
  8. zman
    zman
    from Garner, NC
    pretty much anything where two different types of metal meet. Spark plugs in aluminum heads, on stainless fasteners, exhaust bolts...
  9. Bluto
    Bluto
    Don't use it as engine ***embly lube...........
  10. Busted Knuckles
    Busted Knuckles
    Tef Gel was made by NASA and apparently they had a huge supply of it in a storage locker and someone forgot to make the monthly payment, a guy bought the storage contents at an auction and here we have one of the greatest goos on earth. just a dab on the tip and a bit on the shoulder where a dissimilar metals touch or p*** through.
  11. RugBlaster
    RugBlaster
    Makes a pretty good sandwich spread
  12. noboD
    noboD
    Every repair book I've looked at says NOT to use it on sparkplugs. I have never listened, especially with aluminum heads. Always on Stainless. I use never seize on every fastener I don't use Loc***e.
  13. sho1off
    sho1off
    from Buffalo MN
    use on any bolt or nut you want to take off again or is prone to rust. exhaust bolts. head bolts you get a more acurate toqure reading.
  14. Blown 61
    Blown 61
    If you use it on a bolt that is to be torqued you must reduce the torque value by 15% as it is a better lube then anything, at least that is what they told me when I was building paper machines.
  15. Ken Carvalho
    Ken Carvalho
    From what I have been told...Anti-sieze is VERY,VERY small tiny "particles" of gl*** suspended in a lubricant, and when you put two items together is is lubricated by the "lube" the gl*** particles are in, and after time when you go to dis-***emble the two items (if they are "stuck" together)the small particles of gl*** "break" thus allowing the items to come apart. Like I said this is what was told" to me and it makes sense, but doesn't mean it is accurate?? I use it EVERYDAY at work, and it is slippery and a LITTLE goes a LOOOOONG way....
  16. NVRA #84
    NVRA #84
    I've used it on the inside rim of other peoples ball caps and the receiver on telephones. Don't know why people don't like to turn their backs to me.
  17. sliderule67
    sliderule67
    from Houston
    I like the Nickel based variety; it has no Sulfur which is bad for stainless at high temps. Use it on most everything that is fine thread, high torque or prone to gall.
    Also makes a great office door knob lube. Don't ask me how I know these things, Gr***hopper.
  18. gashog
    gashog
    I've always heard it is a no-no on wheel lugs.
  19. sdluck
    sdluck
    If antiseize is used ,torque on that fastner should be reduced by 50%
  20. bulltown_boy
    bulltown_boy
    I use it on the aluminum threads of light bulbs, they come out much easier.
  21. TooMany2count
    TooMany2count
    from Cahokia,IL
    that's the one place I ALWAYS use it. Have logged 100's of thousands of miles w/o a problem.......joe
  22. no55mad
    no55mad
    Good for carb gaskets too. Ever s****ed stuck gaskets on a Holley 4 barrel? Chapstick works good too - old drag strip trick. I believe the old Neversieze had lead in it.
  23. daveyboy56
    daveyboy56
    The stuff i am using is copper color. I am using it on all the SS on the frame and on the trans to eng bolts (SS) Well most of the botls on the eng are SS now like water pump bolts and alt bolts and that type of stuff. Is that good or bad and should i buy the silver stuff?
  24. Leroy0053
    Leroy0053
    i use it on bolt shanks and some threads for some of the rotor head components..oh wait youre asking for car applications not chinooks right??? ummmm exhaust manifold hardware....hell anywhere that is prone to seize up......wouldnt suggest it on lug nuts though lol..but i use it on exhaust hardware mainly.....
  25. noboD
    noboD
    I've used small amounts on lugnuts for years, never had a problem. The guys that say to lower torque value by a percentage, have you read this in manufacture's literature? I'm sure it's correct, would just like to read it myself. I saw a boss's son that knew everything put neversieze on a tapered pulley sleeve. He wouldn't believe me it should be dry. When he tightened the taper on the shaft it split the pulley.
  26. Shifty Shifterton
    Shifty Shifterton
    Observations on some things in this thread-
    Lowering torque values is a no-no since you should have some form of lubricant on the threads anyway. Anti seize should not alter torque unless you're doing it wrong to start with.
    Spark plugs- ALWAYS in aluminum heads. But be careful slopping it onto the portion of the plug where it's inside the chamber. It will encourage detonation and do weird things if allowed onto the electrode.
    Trivia- did you know some super high temp applications use milk of magnesia as anti-seize?
  27. Crusty Nut
    Crusty Nut
    Thats a good away to get someone hurt.
  28. yekoms
    yekoms
    Like No55mad said a THIN film wiped onto a gasket allows the gasket to come loose without it tearin' apart. (cork valve cover gaskets)
    I heard that anti sieze was developed for the Navy as a sealer against water. Oils thin it and heat thickens it.
    I use alittle Anti seize alot on bolt threads. Also Permatex High Performance Thread Sealer. (the white stuff in white tube)
    It just about always it ends up on my fingers,shirt tail,pants, and then shop rag then from rag back to fingers and so the cycle starts again...
    Smokey
  29. bustingear
    bustingear
    Contrary to some directions from certain areas of California....never,never,never near an *** crack:)
  30. zman
    zman
    from Garner, NC
    Not even funny how dumb this response is... absolutely incorrect...
