Technical Antique Horn Adjustment
Discussion in 'The Hokey Ass Message Board' started by bustingear, Feb 2, 2019.
  1. bustingear
    bustingear
    Just tested this horn with my battery charger. The horn makes noise under both 6 and 12 volt connections. However the noise is more like a raspy sound. I see there are two adjustments on the top but before i dive in and screw it up ...can anyone tell me how to go about it? Suuggestions and direction info and knowledge appreciated
    Regards
  2. brake1000
    brake1000
    from ID
    Its a Sparton horn, under the adjustment screw are points, after awhile the get dirty and stick together, they can be filed down.
    dana barlow and chryslerfan55 like this.
  3. bustingear
    bustingear
    two points of adjustment on top which is the adjustment screw?
  4. Truck64
    Truck64
    from Ioway
    Is it a 6 volt horn? It should probably be adjusted on 6 volts. Find out the current draw, ordinarily I think that's how they were adjusted. With an ammeter in series, sound the horn and adjust till the amperes reach nameplate current draw. It's in the manual somewhere. If it has a condenser (capacitor) that should probably be renewed. Ordinarily they probably never needed adjusting.
  5. dana barlow
    dana barlow
    from Miami Fla.
    Adjust when it's blowing,but don't hold it on for more then a few sec. at a time. Adjust for the sound you like.
    seb fontana likes this.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
  7. G-son
    G-son
    from Sweden
    Hook it up to a battery, not a charger. Old/cheap chargers just supply rectified AC, which pulses at 120Hz (***uming a full wave rectifier and 60Hz AC). A horn will not give the correct sound when the current powering it is chopped up like that, it will mostly "play" the frequency of the supply.
    Truck64 likes this.
  8. Truck64
    Truck64
    from Ioway
    Good catch. Use a battery for testing.
  9. bubba55
    bubba55
    Maybe use 10 amp fuse between battery and horn - once you let the smoke out of them taint no good
  10. 1953naegle
    1953naegle
    I know this is an old thread, but I have the exact same horn as the OP and can't find any specifics about it through Google. Mine is stamped Spartan C-8. Does anyone know what it would have been on originally?
    Mine was one my Dad found somewhere and he had taken it apart to rebuild and potentially use on his 53' Ford F-100, before he p***ed away. It was very rusty inside from trapped water and I finally got it all cleaned, polished, painted and back together. We had to completely take it apart to get all the pieces clean of rust so I'm having to adjust it with no reference of where it was at, but the photo above is very helpful.
