Anvils, do you have one - or more?
Discussion in 'The Antiquated' started by HOTRODPRIMER, Apr 28, 2019.
  1. beatcad
    beatcad
    I'm not a blacksmith nor do I want to be one. But I am a car & sickle guy and need something solid to beat on to straighten brackets and sheet metal.
    Been searching for over 15 years and just got lucky in the last 4 or 5.
    I found a foot tall rail road track that I made a stand for and beat it like it owed me money. I gave it to a friend when I found some of these.
    The 2 little guys. The red one I found at a swap meet for about $35. I wire wheeled it and painted it. Don't believe I've ever struck it. The home made rail road track was made by my wife's grandpa. .
    2 or 3 years ago I found this big guy with the horn broke off. Soda can for size reference. Guy said it was over 100 years old. I think he's right or close. Dunno what it weighed with the horn, but it's about 90 to 100 lbs as is. I really wanted to build a stand and use this one..
    The next smaller one I found locally for $60. I don't think it's vintage and it's maybe only 40/50 lbs. I found a fresh cut tree and made a stand for free.
  2. beatcad
    beatcad
  3. HOTRODPRIMER
    HOTRODPRIMER
    Anvils are a**** the oldest tools still in common use. They’re so old, we’re not even sure who used them first. They’re mentioned in ancient Greek and Egyptian texts, and can be found in ****ol history, as well. Some say metalworking, which required an anvil of some form or another, began in the area of what is today Turkey and Iran sometime around 6,000 B.C. Some of the oldest anvils appear to be found pieces of meteorites, which were incredibly hard because they comprise mostly iron. Anvils have evolved over time from stone slabs to bronze, then wrought iron or iron with a steel face.
    Blacksmiths want an anvil that is “lively.” A lively anvil causes a hammer to bounce back after each blow. In his book A History of Anvils, Sam Moore says the best test of an anvil is “to drop a one-inch ball bearing on the face from a height of 18 inches. If the bearing bounces right back into your hand the anvil is one of the better ones and will be easy to use.”
  4. Dave G in Gansevoort
    from Upstate NY
    I'm just happy to have the use of one for as long as the neighbor leaves it with me. As to whether or not it's lively, I guess I'll never know...
  5. For those of you using a piece of railway iron, I give you this one from the now closed Walter P Chrysler museum display. Humble beginnings. 4627FD88-0B71-41D9-9131-3301E2313E89.jpeg
  6. Beanscoot
    Beanscoot
    Were they ever made with built up material on the horn? Or was this one repaired so expertly that it's held up to who knows how many years of continued use?
    BigRRR, deathrowdave, Deuces and 3 others like this.
  7. High test 63
    High test 63
    IMG_20230816_113358937.jpg one i picked up at a local s****yard. Owner (who i know) was using by his scalehouse. He didn't want to sell it but i offered a similar weight one for trade and some cash to boot. The one i traded had a couple broken spots and the table was not nearly as nice.
    I ground a bunch of chisel marks out of the horn and put it to work. Ive made several tools to fit it and made a few knives and muzzleloader parts on it.
    Fordors, BigRRR, alanp561 and 3 others like this.
  8. High test 63
    High test 63
    Id guess it's been nicely repaired.
    Deuces likes this.
  9. Beanscoot
    Beanscoot
    I admire talented welders!
    Deuces, Okie Pete and '28phonebooth like this.
  10. dana barlow
    dana barlow
    from Miami Fla.
    The one I have had from my Grandad,,,is some were under too many parts,is about 1 foot + of RR rail,made into anvil. It's under the stuff,do to I got a big vise after,and beat stuff up on the vise . So I guess it's helping hold the floor down,mostly..
    BigRRR, Okie Pete and Deuces like this.
  11. Dave G in Gansevoort
    from Upstate NY
    Most good older anvils were wrought iron, similar in makeup to today's mild steel, like a 1010 hot rolled steel. I found this out when repairing the neighbor's anvil where a leg was broken off. Weld prep for complete penetration, preheat, weld with nickel rod just because..., and postheat. My brother always said that I could break an anvil. Well I'm one up on him now. I've fixed a broken anvil!
  12. Okie Pete
    Okie Pete
    I have this little one . It stands 3 1/4” tall , 6 1/2” from the point of the horn to the edge of the deck . No name or numbers IMG_6594.jpeg
    BigRRR, Deuces, tractorguy and 3 others like this.
  13. 7DB45358-AD3C-43A0-9BCD-42AB19BF2F5C.png Do pexto pieces count ?
    I just added these to my collection.
    That big one is 41”.
    I made a Quickie mount from a trailer hitch receiver welded under my table. There when I need it and not when I don’t.
  14. 1952henry
    1952henry
    My 150lb Lakside on top of an almost as heavy oak beam.
    Champion No.203 blacksmith belt driven drill press. All 425 lbs of her hanging on an 8x8 oak beam. Took it all apart, cleaned and painted it. Some parts cleaned and wiped with beeswax/ motor oil paste.
    Both thanks to Uncle Donald!
    BigRRR, Deuces, Okie Pete and 4 others like this.
  15. HOTRODPRIMER
    HOTRODPRIMER
    I would have jumped on a 40 dollar anvil like a duck on a June bug, it will still work for pounding metal. HRP
    SS327, Deuces and chevy57dude like this.
  16. Dave G in Gansevoort
    from Upstate NY
    Me too. They don’t “ring” due to a crack in it. That was also a test for forging before magnaflux. For instance if a forged crank doesn’t ring, it probably has a crack.
  17. chevy57dude
    chevy57dude
    Thanks, guys. Yes, I'm glad I got it.
    Deuces, Okie Pete and SS327 like this.
  18. 65pacecar
    65pacecar
    from KY, AZ
    Yes, including a small one for trim restoration.
    Deuces, Okie Pete and down-the-road like this.
  19. HOTRODPRIMER
    HOTRODPRIMER
    There are cast anvils out there that don't ring, it really doesn't matter as most of us are using the anvil for pounding and shaping steel & aluminum, not hot molten steel. HRP
  20. High test 63
    High test 63
    Yes, doesn't mean it's cracked if it doesn't ring. Like HRP says its, its probably a cast anvil. A lively "ringing" anvil is a desirable feature mostly if you're trying to make a living at blacksmithing. A " dead"
    sounding anvil will meet 99 pct. of most people's needs,.... A flat, straight, hard surface.
    Deuces, Okie Pete, alanp561 and 3 others like this.
  21. High test 63
    High test 63
    I have a couple really "nice" anvils that ring so much that you can't hardly do any amount of work on them without wrapping a chain around them to deadn the noise and earplugs are a must.
  22. Chief 64
    Chief 64
    There are some nice anvils in the H.A.M.B. community!! But how many of you have a Solid Gold anvil?? Well, I don't but I do have a solid br*** one that looks like gold:D:D. My parents had a br*** anvil on the kitchen counter as a paper weight when I was growing up. My Dad probably got it as a trinket from a specialty metals salesman when he was buying specialty metals for his shop. One day I saw a br*** anvil at my sons house. I said your Grandpa has one of those br*** anvils. My son gives me a funny look. My dad gave it to my son. I always wanted it.:mad: Several years later my son found this one at a flea market and bought it for me. I wet sanded it and buffed it. I use it on my desk for a paper weight.
    Several years ago another son of mine gave this one at Christmas. He knows the owner of Holland Anvil and their factory is not far from us. I use this one for a paper weight in the barn.
    Fordors, BigRRR, Deuces and 5 others like this.
  23. 41 GMC K-18
    41 GMC K-18
    I think you all will find this particular video, to be very entertaining!
    Thanks from Dennis.
  24. beatcad
    beatcad
    i kinda forgot about this thread until last night.
    this one i use the most is also at the top of this page. last year i took a length of an old belt my wife had in high school.
    made a loop hammer holder..
    the little one i bought from eastwood over 16 years ago. i also bought the suggested hammer.
    the pair is sold to straighten stainless car trim and ive used it for that.
    lately ive used it making copper bracelets out of left over romex 20250429_173527.jpg 20250429_173125.jpg
  25. Jeff34
    Jeff34
    While not an anvil, this serves me well. It’s a 5” X 2” X 20” piece of stainless steel I inherited from my dad. When we had the estate sale, everyone was looking for this and asked who got it IMG_4938.jpeg
  26. Deuces
    Deuces
    Check this out!.....
  27. Jack Rice
    Jack Rice
    No pics but I have my Dad's old anvil. It is made from a chunk cut from the main driving arm off a wrecked steam locomotive. It has a horn shaped with a steam hammer and a nicely machined top suface. It weighs about 70lbs and has a nice lively ring. It's easily a 100 year old chunk of iron.
  28. BigRRR
    BigRRR
    Did someone say railroad track anvil … yep have one too :) IMG_2992.jpeg
  29. poco
    poco
    from oklahoma
    My anvil is a short piece of a railroad tie
    High test 63 and down-the-road like this.
