Any 283 guru's here?
Discussion in 'The Hokey Ass Message Board' started by NewBlood, Apr 4, 2008.
  1. NewBlood
    NewBlood
    Building a 283 for my 51 Chevy Truck and need some advise.
    Bored .60 over, turbo 350 with a 2000 stall, 3:73 gears. I think I'm going to be running the powerpack heads that were on it after I freshen them up (new spring and seals). Now the big problem is trying to figure out what cam to run. I'm leaning towards this and wanted to know what you guys thought...I was looking at this from an economy stand point and it looks like a great deal. I just dont want to build a non streetable engine. Any help would be much appreciated.
    <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD>Elgin, Hyd. Flat Tappet Complete Cam Kit, Chev SB, .465/.488</TD></TR><TR><TD cl***=plaintext>Chev SB
    Lift: .465/.488
    Duration: 298/304
    Duration @ .050": 224/234
    Lobe Separation: 112 LC
    Moderate rough idle, Auto require higher stall, Street/strip
    </TD></TR></TBODY></TABLE>
  2. 52 csb
    52 csb
    Great cam if you had a 4 or 5 speed! my 5 cts worth.
  3. tomslik
    tomslik
    looks like a lot of camshaft for a basicly stock 283 (292) and not much of a converter
    it'd be a lot tamer in a bigger engine....
  4. Roothawg
    Roothawg
    Too much.
    How about.....
    COMP Cams K12-206-2
    $285.95
    Estimated Ship Date: Today
    Brand: COMP Cams
    Product Line: COMP Cams High Energy Cam and Lifter Kits
    Part Type: Camshaft and Lifter Kits
    Part Number: CCA-K12-206-2
    Cam Style: Hydraulic flat tappet
    Basic Operating RPM Range: 1,200-5,200
    Intake Duration at 050 inch Lift: 212
    Exhaust Duration at 050 inch Lift: 212
    Duration at 050 inch Lift: 212 int./212 exh.
    Advertised Intake Duration: 260
    Advertised Exhaust Duration: 260
    Advertised Duration: 260 int./260 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio: 0.440 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.440 in.
    Valve Lift with Factory Rocker Arm Ratio: 0.440 int./0.440 exh. lift
    Lobe Separation (degrees): 110
    Intake Valve Lash: 0.000 in.
    Exhaust Valve Lash: 0.000 in.
    Grind Number: CS 260H-10
    Computer Controlled Compatible: No
    Lifters Included: Yes
    Lifter Style: Hydraulic flat tappet
    Valve Springs Included: Yes
    Outside Diameter of Outer Spring (in): 1.230 in.
    Retainers Included: Yes
    Locks Included: Yes
    Valve Stem Seals Included: Yes
    Timing Chain and Gears Included: Yes
    Timing Chain Style: Double non-roller
    ***embly Lubricant Included: Yes
    Pushrods Included: No
    Rocker Arms Included: No
    Gaskets Included: No
    CARB EO Number: D-279-3, D-279-5, D-279-6
    Quan***y: Sold as a kit.
    Notes: Operating rpm for marine applications is 1,800-4,900. For 1987 and earlier carbureted Chevy 262-400
    Cam/Lifters/Valvetrain, Hydraulic Flat Tappet, Advertised Duration 260/260, Lift .440/.440, Chevy, Small Block
  5. NewBlood
    NewBlood
    What about this one?
    <TABLE cellSpacing=1 cellPadding=3 width=630 border=0><TBODY><FORM action=http://www.compe***ionproducts.com/itemadd.asp?additem=E1166K method=post><TR><TD cl***=tdRow1Color vAlign=center align=middle></TD><TD cl***=tdRow1Color vAlign=top><TABLE cellSpacing=0 cellPadding=0 width="100&#37;" border=0><TBODY><TR><TD>Elgin, Hyd. Flat Tappet Complete Cam Kit, Chev SB, .453/.480</TD></TR><TR><TD cl***=plaintext>Chev SB
    Lift: .453/.480
    Duration: 282/294
    Duration @ .050": 216/228
    Decent idle, Street/strip applications
    </TD></TR></TBODY></TABLE></TD></TR></FORM></TBODY></TABLE>
    The guy at the machine shop wanted me to go with a Lunati Voodoo #60102 262/268 219/227 @.50 468/489 112 seperation
    I thought this was too big also.
  6. NewBlood
    NewBlood
    Thanks RootHawg..I think thats more in line. I dont want to go to big, I want it to sound good but be streetable and driveable.
  7. olscrounger
    olscrounger
    go with the comp 260 degree as someone mentioned or Crane 266 degree with 440 lift--both will idle well in a small cubic inch engine and produce decent vacuum-any mor ecam than these and you will lose low end.
  8. NewBlood
    NewBlood
    Appreciate all the insight guys
  9. novadude
    novadude
    Isky 262 supercam 262/262, 208/208, 108 LSA.
    About the biggest duration I'd run in a 283, and the 108 LSA and resulting overlap should give a bit of teh sound you are after. Anything that sounds TOO wicked in a 283 won't be very streetable.
