any creative use for these aluminum water bottles?
Discussion in 'The Hokey Ass Message Board' started by Mark, Dec 10, 2011.
  1. damagedduck
    damagedduck
    from Greeley Co
    X-mas gifts :D
  2. Deuces
    Deuces
    I'll have to check the diameter of those with my calipers.. I think they're 22 oz bottles..:confused:
  3. Bad Bob
    Bad Bob
    from O.C. Baby
    HAHAHAHAHA!
    How about a portable pisser? For when you're waiting in line at a show?
  4. mj40's
    mj40's
    If used as a overflow, do they also need a drain tube some where so they will not build up pressure?
  5. Brad54
    Brad54
    from Atl Ga
    I've got a couple of those too.
    Use EZ-Off oven cleaner to strip the anodizing. Blasting or wire wheel will kill them.
    Once bare, use some 000 steel wool and twist it around the bottle to give it a brushed finished.
    I'm going to make an aluminum bracket to weld to the side of the thing and cap the open end. Drill a hole in the open end for a radiator pet**** (drain), and drill a hole in what was the bottom and stick a piece of aluminum line down into it (with a slash-cut on the end). Then attach the overflow hose on the radiator to it.
    Upside down, it won't be obvious it's an aluminum beer bottle, and with the taper and the end, it's functional.
    -Brad
  6. Jeem
    Jeem
    Alliance Vendor
    Target always, has a nice ***ortment of car parts in their home furnishing section for some reason. Tig required.
    Car parts are where you find 'em.
  7. Ha Ha read my mind!
  8. Deuces
    Deuces
    I've also had the crazy idea of making fake fuel injection stacks for my pony....:rolleyes::eek::eek:
    Yeah, I know..... Somebody beat that guy over the head!! :rolleyes:
  9. gasolinescream
    gasolinescream
    Yep i think they call them the 3am urine storage containers. A hotrod camping essential.
  10. brett4christ
    brett4christ
    What about mag wheel centers? Cur them in half, put the bottoms on one side and tops on the other.....
  11. GeezersP15
    GeezersP15
    from N.E. PA
    Here's the overflow for my Plymouth. Welded a length of aluminum angle to the side to attach it. Connection from radiator has 1/4" tube to about an inch from the bottom. Other connection is the overflow drain. Holds about 1.5 qts. Works well so far. Polished it up on a buffer with a bit of compound.
  12. Energy
    Energy
    Polish them up, then use some Blue paint and paint/letter "NOSS" on them, just to mess with the idiots!
    Run some old braided lines to each of them, hooking them in series.
    :D
  13. Ruiner
    Ruiner
    Too bad they're not big enough to be made into steering column adapter covers...
  14. DE SOTO
    DE SOTO
    This type of statement is what holds the Rat Rod Craze together.
  15. Jeem
    Jeem
    Alliance Vendor
    Oh! Well then perhaps I should clarify.....
    Car parts are where you find 'em as long as they are used for good and not evil.
  16. larry woods
    larry woods
    from venice fl
    how about windshield washer reservoir? like the gauge ide and of course the radiator overflow.
  17. rusty76
    rusty76
    from Midway NC
    I just would drink out them, no antifreeze for me though. Blast'em, paint'em and stripe'em or some traditional style paint job to them.
