Any Difference Running Straight or Progressive On a Blower?
Discussion in 'The Hokey Ass Message Board' started by 345 DeSoto, Apr 17, 2011.
  1. Got 2 bone Stock Carter 500 CFM Compe***ion Series Carters on my blown 291 Hemi. Am about to put them back on after going through them for this year. I ran them progressive last (first year) year and am kicking around the idea of running them straight this year. I have them both set up to idle, but I'm wondering if there is any advantage to running them straight...other than adding to the Oil Companies profits. I THINK the fuel distribution might be better, but I hear so much stuff about running them one way or another, that it confuses me. I know one HAMBer said that running his straight woke up his blown Hemi, But I'm just wondering about the BEST setup to use. Thanks, guys...
  2. Spyder
    Spyder
    from Houston
    I just picked up some AFBs myself and wondering the same thing. I had thought it would be easier to run them progressive and only use a choke on one of them. I would also not have to worry about the secondariess opening at the same time and the metering rods moving at the same time.
  3. Anybody on the night crew?...
  4. flamedabone
    flamedabone
    I tried to run progressive when I first put my blower motor together and fought a light throttle stumble for weeks...I finally hooked them up straight and the diffrence was night and day.
    Now, after doing some pretty extensive dyno testing, I know that even at low RPMS and part throttle one carb wasn't gonna cut it. My advise is to hook em up straight.
    Good luck, -Abone.
  5. Thanks, Abone. You were the one I was refering too. Did you do any Dyno testing progressive, or straight only. Funny thing is, I'VE got the same stumble...
  6. kkustomz
    kkustomz
    from Texas
    I would suggest you running them staight, the only down fall is your cubic inch is so small, but it should work fine with two 500's
  7. Too few cubes?...
  8. 39coupeute
    39coupeute
    from australia
    ran 2 500 cfm edelbrocks on a 302 windsor not blown with a progresive linkage and never had a problem.they were straight out of the box as well .
