Hey guys, I'd like to run an engine turned dash panel in the '34. I have a bunch of stainless and Aluminum sheet, but I don't have the time/patience to turn a panel myself. I see that Eastwood sells pre-turned panels, but they seem pricey to me. I'm guessing I'll need something roundabout 8"x36", I figured around .040" thick, but Eastwood has .030" or .062", so anything in there could work. I can either buy a pre-done sheet (Aluminum or stainless, whichever's easier), or pay you to turn my material (probably 1/2" or 3/4" pattern). Let me know guys! Thanks! Steve
FPM Inc. www.fpmmetals.com 402.729.2264 They are in Fairbury Neb. Seems to be the best I've found. Good luck.
im not sure how "perfect" your car is but i can do engine turning...i do it by hand so its not factory looking but i guess its about right for a hot rod heres a thing i was working on with my name to set at work ...just to give you an idea its .063 3003 half hard aluminum i have no idea how to charge...i guess just however long it takes me? let me know if you have any interest zach
I posted a Tech on this a while back.... hope this helps http://www.jalopyjournal.com/forum/showthread.php?t=36927&highlight=chaz If the link doesn't work search "Custom dash tech"
Get ahold of Goldenboy here on the HAMB he is a jewler and has a real engine turning machine from the 1930's and can do enamel badges and stuff like that.
There was a really good thread in the Tech O'Matic, but I guess that was a while ago. A milling machine makes it relatively simple, but it's still time consuming. Here's an link that might be interesting: http://www.cs.ucr.edu/~eamonn/et/et.htm Thanks, InDaShop, for the link to FPM. Not only are their prices much better than Eastwood's, but they also offer 0.063" stainless, which Eastwood doesn't. --Matt
FPM Metals owner, Steve Gasper is a fellow 'rodder and vintage oval track restorer/racer. An all-around nice guy too!! Regards, Gerry Dedonis The Kansas Auto Racing Museum http://www.kansasautoracingmuseum.org Chapman, Kansas
