Projects any idea how to fix an exhaust manifold leak without removing the manifold?
Discussion in 'The Hokey Ass Message Board' started by oldcarsandglass, Oct 6, 2009.
  1. oldcarsandglass
    oldcarsandglass
    from Minden la
    My straight eight has a decent exhaust leak on the manifold - not sure if the gasket blew out on the top of one of the ports or what -
    i can replace the gasket, but hate to take the manifold off - my luck, i'll twist a bolt off in the head.
    any ideas about how to seal up the top of that port without removing the manifold? i've thought about something like JB Weld...
  2. brokenspoke
    brokenspoke
    Your kidding......
  3. InsaneEmpire909
    InsaneEmpire909
    from 909
    I hope he's kidding,
    real easy start taking off the bolts, if any give you problem (which I doubt) but if they do just skip them and spray some penetrate and let it sit. dont use jb weld to make a repair their are plenty of people selling or even giving away manifolds on here or craigslist. good luck
  4. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    Duct Tape and wire works well!!
  5. x2
    Just make sure you use the "silver foil" duct tape and not the "grey" stuff and everything will be fine :D
  6. BJR
    BJR
    I use Play Dough, it hardens up just great with heat. And it tastes good too!
  7. TrannyMan
    TrannyMan
    Y'all guys quit messing around. I would braze that thing up.
  8. Edelbroke
    Edelbroke
    braze around the bolts too, sometimes you get leaks there
  9. 19-c
    19-c
    I have used that spray foam in a can and had pretty good luck!:eek:
  10. onlychevrolets
    onlychevrolets
    I've been doing exhaust work since 1977 and I have not found any short cuts to fixing a manifold leak. Start spraying the bolts with PB now and by this weekend try and get it off. An impack set on low is better than a hand ratchet. The shock of the impact tends to break the rust loose. Go slow and spray often. It'll come off
  11. 61TBird
    61TBird
    Weld them up using wire hangers(just like they did in the '50's:rolleyes:),if that doesn't work,wrap the exhaust in Dryer sheets....
  12. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    They sell that exhaust stop leak....it works pretty good....look for it in Auto-z right next to the radiator stop leak:rolleyes:
  13. onlychevrolets
    onlychevrolets
    I remember you....:mad:
  14. bobwop
    bobwop
    from Arley, AL
    header wrap and some hose clamps is a temporary fix.
  15. bonez
    bonez
    from Slow lane
    Not to hijack, but wasnt exhaust leaking something totally not to worry about?
    I thought it was a big issue on a 2 stroke engine.
    Of course im not saying leave it as is, as i'd fix it myself, im just wondering if my
    knowledge is bs or if im right about it.
    Then on your question:
    I personally would listen to Onlychevrolets and take the header off. Pretty easy from there on.
  16. Damn you guys are hard,,,LOL. But it is true,,,,,,,ya just caint fix stupid
  17. Shifty Shifterton
    Shifty Shifterton
    As mentioned start using penetrating oil now, and use engine heat to your advantage by spraying the bolts after a drive and letting the cooling action wick the oil in.
    Depending on access, you may not need to entirely remove the bolts or the manifold. A lot of designs you can loosen about 3 turns, poke the old gasket out, and drop the new one in.
    If the bolt twists off, there's a good chance it wasn't applying much clamping force to begin with, and was part of the root cause anyway.
    good luck
  18. 28hiboy
    28hiboy
    from Milton, Fl
    Are you the same guy that welded his pinion to the ring gear to make a locker?
  19. I saw that, right next to the "engine rebuild in a can".
    Bob
