Technical Any ideas what the heck this is???
Discussion in 'The Hokey Ass Message Board' started by Smokin' Joe, Aug 20, 2015.
  1. Smokin' Joe
    Smokin' Joe
    This came from the widow of an old-timer and so far, I can't find anyone that knows what it is. Any thoughts???
    The large fitting is for an air line, and across from it is a petcock, and then at the bottom is a threaded male fitting... been scratching my head, so I figured somebody on the HAMB wll know
  2. Hdonlybob
    Hdonlybob
    Sure don't but anxious to fine out :)
  3. 49ratfink
    49ratfink
    is that an air chuck on the top?
    maybe some sort of drip oiler for something like a hit and miss engine or some sort of machinery
  4. That was my first thought as well. Home made doo-hickey for a specific job. Very cool.
    kiwijeff likes this.
  5. 49ratfink
    49ratfink
    ha ha we have a winner "Home made doo-hickey for a specific job".
    I would write that on the bottom so you don't forget.
  6. cad-lasalle
    cad-lasalle
    from grafton nh
    I have something like that I made to attach to the oil sending unit hole to prelube a new engine or one that's been sitting around. When oil comes out around the rockers it's ready to start.
  7. Kinda looks like a very early version of the Mellings pre-oiler I got.
  8. It is certainly a pre-oiler, but I would not have used an oil can or anything with thin walls. If the air pressure regulator is set too high that would be a bomb.
  9. Probably a home-made power brake bleeder..... That doesn't need much pressure.
  10. only Cad-Lasalle would have something like that
    pitman likes this.
  11. Budget36
    Budget36
    I'd agree, can't see that can holding 15+PSI to pre oil an engine, but a few pounds of pressure for brakes?...ya, I could see that.
  12. A tester for JB weld to see it would hold while wet with oil.....
    An atomizer for spraying cleaning fluids, the paint would have peeled from brake fluid.
  13. pitman
    pitman
    Cad-Lasalle has garnered much of the early-days methods,
    and wisdom! ;)
    Got to hear the one about Uncle Jun who took flight into the trees, :eek:
    from a '31 launch-pad.
  14. Crankhole
    Crankhole
  15. 03GMCSonoma
    03GMCSonoma
    Looks more like thingamajig.
    Bob
  16. butch27
    butch27
    It's a "gritzel pivot that attaches to an early Ford " snarvel valve" Probably earlier than 1940. LOL
  17. Yep before 3" PVC was available. :D
    lothiandon1940 and COOTER like this.
  18. lodaddyo
    lodaddyo
  19. Actually with the petcock I would almost bet it is a water trap of some sort.
  20. Jethro
    Jethro
    First thing I thought too!
    I found one of those under my kids bed when he was in high school
  21. Bruce Lancaster
    Bruce Lancaster
    Old air-power enema machine. Used to be very common...doctors carried them in the trunks of their cars, hooked up with a hose to the spare tire. Main use was in rural areas with no electricity and Amish patients.
    Pressure was critical...too much, and the results were HIGHLY unfortunate.
    pitman and lothiandon1940 like this.
