Hot Rods Any Info on these Federal Mogul Bronze Heads?
Discussion in 'The Hokey Ass Message Board' started by jambottle, Feb 26, 2013.
  1. jambottle
    jambottle
    Just got these.Any info,pictures ,history.Thanks
  2. bowie
    bowie
    Mostly made for marine use. Some of them are made of a copper/brass alloy. Pretty dang rare, in any form.
  3. the-rodster
    the-rodster
    Do a search on here for Federal Mogul, you'll get lots of info.
    That is the first set of 24 stud FM heads that I have seen.
    Rich
  4. alchemy
    alchemy
    Did you get the water manifolds with them?
  5. jambottle
    jambottle
    i did not get the water manifolds.i guess the 21 stud ones are proably different.
  6. Groovybaby6
    Groovybaby6
    from Denver
    The Bob McGee roadster has those.
  7. Elrod
    Elrod
    ^^ Bob McGee is the 21 stud. Interesting that you found 24 studs!
  8. Bruce Lancaster
    Bruce Lancaster
    I would guess tha manifolds would be the same...all the differences for 24 studs are in the bottom row of studs.
  9. jambottle
    jambottle
    Hi Bruce ,it`s been awhile since we communicated..i thought the out side holes at both ends were placed higher on the 24 stud ones.it`s been a long time and my memory is getting bad.
    i think they may fit too.Just to be sure ,i will order both sets from J.C.Whitney and send the set back that does not fit.Chris
  10. Bruce Lancaster
    Bruce Lancaster
    The JC Whitney Federal Mogul pieces are Chinese...skip'em and get the genuine "Help!" brand ones at Advance Auto.
  11. the-rodster
    the-rodster
    You guys are probably causing a lot of newbies to scratch their heads.
    Rich
  12. Bruce Lancaster
    Bruce Lancaster
    What's are "newbies"???
  13. Well Bruce I guess I am a newbies, I have never even heard of bronz heads, totally newbies-ish for sure or totally newbies information to me. :D
    Pretty darned cool, and I have learnt somethin' new da-day, now I can take a nap. ;)
  14. Bruce Lancaster
    Bruce Lancaster
    Waterless heads on top of a flathead is a scary concept! Then you realize why they did it! Those water filled kinds just won't make decent waffles...everything runs down onto the exhaust before it gets hot enough. Feh.
  15. jambottle
    jambottle
    I agree Bruce;They are very heavy compared to the Canadian ones i have on the roadster.I wonder how much weight i can save by milling the fins off?Chris
