Any of you clowns actually BUILDING something???
Discussion in 'The Hokey Ass Message Board' started by hatch, Feb 11, 2007.
  1. RICKY MCGREGOR
    RICKY MCGREGOR
    from wichita ks
    Put 134 louver in a 50 MERC hood,and helped JRSIRON haul a truck load of model A parts home.
  2. fordv81931
    fordv81931
    trying !!!!!
  3. sko_ford
    sko_ford
    just a little grinding on the 9"
  4. gbones32coupe
    gbones32coupe
    I patched the holes in my floor and mounted my battery
  5. Did a couple hours of wiring in the garage, and a couple hours cleaning yesterday. Went to the airport and put motor mounts in the Ercoupe today (since when are Lord mounts an improvement over the old C85 Continental type?).
    Didn't build a damn thing.
  6. fab32
    fab32
    Still destroying (taking apart) the '64 ElCamino. Couple more things then it's time to start re***embly. Biggest problem is deciding how far to take apart, this was just going to be a quick fixer upper to have a driver for next summer, but you know how it goes.
    Should start bolting parts back on this week sometime.
    frank
  7. Vance
    Vance
    from N/A
    I finally got the garage warm enough to spray some primer! If my luck holds out I'll be giving my coupe a checkered future next weekend... Well at least it's firewall. I'll be posting photos as I go along with some twists with the how-to, so all you guys that were asking for help stay tuned.
    Vance
  8. john56h
    john56h
    Nice Cutl***!
    I'm a 64-65 Oldsmobile fan. Here are a few that I have:
    [​IMG][​IMG]
    Here's a convertible of my brother's and stock car that is ours:
    [​IMG][​IMG]
  9. Tin Can
    Tin Can
    Redoing the interior of the Buick....No pics yet, almost done though.
    Collecting parts for thetudor sedan that I just picked up.
    Working on the 28 ford truck for truckedupmodela on here. I will have to post pics soon of all projects.
    I feel like I have a second job Ive been at the shop so much lately
  10. Don Moyer
    Don Moyer
    Filled the wood burner up, got the garage up to 85 degrees and sanded, and sanded, and then sprayed some primer....next day I finsihed sanding and got to the ****it stage, and broke out the Laquer and got ready to paint. Then I thought about it.............got a shovel and took all the burning hot coles out of the wood burner and took them into the house and put them in the fireplace (wouldnt want to waste free heat). Then I mixed the paint and spayed the doors and grill shell on the 32....Looks pretty good, will mount them this week to see if the color is close enough......Went to a drag racing swap meet today in the mourning.....first swap meed since the 80's that I did not buy anything.....wtf........must be ebay, or my tight ***!
  11. Slingin' a little mud and stripping paint on this over the weekend.
  12. Vergil
    Vergil
    Raining so I took a pict of what is done and ignored what needs done, it was an easy decision.
  13. Scrubbed down my new to me, Ford Bronco 9 inch rearend for my 34 pickup.
    CBB
  14. MIKE-3137
    MIKE-3137
    Finished my firewall and floor at last..,fixed some rusted areas on the cowl, final welded the body and engine mounts with the tig, hooked up and tested my homemade clutch linkage/bellcrank ***embly, fit the dash I made, yanked the engine back out to fix a shifter issue, started the wiring process. Everytime I think i'm getting closer i find 50 more things, but I think i'm getting closer.
  15. desertdroog
    desertdroog
    I insulated the floors on my 54 to get it ready for interior. Used a sort of dynomat, thick metal foil with sticky black tar backing. Got it from the front kick boards all the way back to my rear seat area. Soon I will have pics of my carpet and seats done, then on to the door panels.
  16. rabidcustoms
    rabidcustoms
    from Iowa
    yep, building something....what I dont exactly know, well I kinda do,...it could easily be described as a huge waste of time and money,....but it mostly keep me out of trouble, so thats worth something there right?:D
  17. mad-cad
    mad-cad
    I've been giving the 56 caddy coop some attention,the engine and ****** mounts are done so I can bolt in a 500 caddy motor and the matching TH400.
    Finished off the ****** mount then pulled a complete 500 and TH400 out of storage that I'm going to use in the 56.Primed the oil pump and engine with the drill,it made good oil pressure,spun the motor over and it made good compression .So it'll be getting a rattle can rebuild:D and bolted into the 56
  18. Painterman
    Painterman
    Got the rear end finished up in my 37 pickup. Added a panhard bar, shock mounts and all new stainless hardware. It's comming together now!!
  19. Tdreamer
    Tdreamer
    striped a few things with the one-shot vance sent me...decided I needed more color went to hardware store and picked up some xo-rust to practice with i'm getting there for only a few days stripen, still not dead on symetrical:p ...talked to a guy on some 47-48 chevys...buying one tommorow:D
  20. bill haggerty
    bill haggerty
    bb 400 chrysler in my 41 plymouth coupe.chopped the frame w/volarie clip.
  21. Bgoodman
    Bgoodman
    well, the unfinished pickup is at home and i'm out here at school so i did what any respectable student would do of course... i went to the SACRAMENTO AUTORAMA!
  22. 6volt jolt
    6volt jolt
    Rounded up some varnish and other supplies to stain my new bed wood. Aired up the left front tire. Adjusted the idle on the carb, found it leaking gas in 3 places. Pulled it back into the garage. Staged a fire extinguisher close by. Ordered some new gaskets. Shoveled dog **** in the back yard. Ran some stuff to and from the storage shed on the snowmachine. In other words, not much progress!
  23. langy
    langy
    I've been making this fit my 32 project.
    Steve.
  24. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    My pickup i started building in Oct....Hope to have it running in a few weeks
  25. DIRTYT
    DIRTYT
    from Warren,MI
    I got my new engine all together and put into my Camaro. Hopefully by next weekend i can be driving the ****er again. Im about to go out right now and put the new heater core in and put the fender back on. The sooner i get this damn thing done the sooner i can start on my real projects, my Merc and my Chevy.
  26. Rocket
    Rocket
    from Austin Tx
    I got new tires, stripped more paint, torqued down the 3X2, removed all the interior and loosed some things up to start a rewire. Oh and lowered my friends edsel 3" front and back.
  27. Lucky77
    Lucky77
    Had breakfast with some clowns, (Thanks for the electrical help) cleaned up the shop after my model A induced mental meltdown. Put my coilovers together, ***embled my brake pedal setup and got the ch***is on a level surface to square it up. Plus I got the old Monte SS running again. Hatch, that coupe's looking so bad*** I'm pretty sure it's out of my price range now. Andria is going to be really disappointed.
  28. Scott
    Scott
    Getting it done Here
  29. HOTRODPRIMER
    HOTRODPRIMER
    Still waitin' on the wagon to get back from the painter,,,so,I decided to yank the dead 327 outta the chevy II ,,,
    The poor ol' Chevy II will end up in the barn,,,but the 327 will end up in my 32 pick-up,,,HRP
  30. 53sled
    53sled
    from KCMO
    made a comfy place to sit on my ***...
      41.7 KB
