Technical Any of you old engine builders ever......
Discussion in 'Traditional Hot Rods' started by 6sally6, Aug 6, 2024.
  1. 6sally6
    6sally6
    Built an engine with negative deck height ? Where the piston crown is ABOVE the deck of the block? It would probably require the use of dished pistons to work right. In theory the combustion process would happen in the dish of the piston. Concentrating the power in the piston dish instead of power scattering across the crown/flat top of the piston and the combustion chamber.
    Think it would make more power OR the added cost of custom thickness head gaskets and/or custom pistons/rods would make the whole thang a 'wash'?
    This might go into the same category as the long rod theory !?! (some of the girl friends might enjoy this particular theory!) jus say'in.
    Rainy weather brings up a lot of these questions in my tiny brain...............
    Thx in advance
    6sally6
  2. RodStRace
    RodStRace
    Lots of different deck heights out there
    hemi
    rod1 likes this.
  3. lumpy 63
    lumpy 63
    A lot of race engine builders run em outa the block. most guys shoot for an .040 quench but some guys really push the limit depending on rod and piston combo's
  4. Mike VV
    Mike VV
    from SoCal
    A somewhat normal thing to do with drag race style Chrysler Hemi's.
    A change in piston pin location (piston "in the hole" or "out of the hole" was used to increase or decrease the compression ratio, depending on many things. Track location (Colorado vs. Calif), track condition, that is available traction. Ambient temperature and humidity, (again, horse power to be made with the current air density).
    Some street engines could be built the same for the same reasons as noted above.
    Mike
    Outback likes this.
  5. 29Sleeper
    29Sleeper
    from SoCal
    The pistons on a stock Model A stuck up out of the bore about .030.
    hotrodfil and winduptoy like this.
  6. iagsxr
    iagsxr
    I know a guy who used to build a lot of Claimer sbc oval-track engines with the pistons out of the hole.
    I could see places where you could do it even on a street motor. Like if you were committed to using certain heads.
  7. lippy
    lippy
    from Ks
    Sometimes what you believe is right is not for all applications. ;) In other words, there's a hundred ways to skin a cat. But the cat, he don't like none of them. Nitro tuning talk. Lippy
    anothercarguy and G-son like this.
  8. RICH B
    RICH B
    Question made me think of these pictures that Tim McMaster posted of an engine he built.
    Outback, winduptoy and rod1 like this.
  9. Buick Nail Head.
  10. jaracer
    jaracer
    I don't think my 401 had the piston above the deck. The pop up on the piston was, but not the piston. IMG_1299.JPG
    2OLD2FAST likes this.
  11. ^^^^ Guess I needed to read the post a little better. Crown, not top of piston....
  12. FrozenMerc
    FrozenMerc
    Basically every wet sleeve engine ever built has positive piston protrusion.
  13. Unkl Ian
    Unkl Ian
    On a small bore, some will go tighter than .040" quench clearance. I think we ran .030" on a OT race motor.
    We used to buy semi finished pistons, and I would do the final machining on the crown. Compression height,
    dome height, valve notches. We started with the official factory specs, but wanted more power. And we got it.
    Did one motor, seemed to make more power than usual. Hmmmmm. Strange. No idea why.
    On the next tear down, we noticed the ends of the piston domes had been touching the head.
    Didn't hurt anything else, turned over fine on the stand. Serious RPM does strange things.
    The domes got massaged just a little more in those spots. Never blew up a motor, wanted to keep it that way.
    Outback, Driver50x and lumpy 63 like this.
  14. TA DAD
    TA DAD
    from NC
    We called it " outta the hole "
    427 sleeper and Unkl Ian like this.
  15. chicken
    chicken
    from Kansas
    Yep, I try to do it with every engine I build that has quench area. Shoot for .040" most times, but my own stuff gets cheated a bit closer, like the .033" on my 8CM flathead in the Merc. It's worth the trouble.
    Unkl Ian, rod1 and Outback like this.
  16. It all depends on the engine, the heads, the desired quench, etc.. I've frequently used custom piston pin locations (compression heights) on some of my flathead build to achieve a .040 quench (without milling the heads). If you use a quench of less than .040, then you do need to validate how much piston "rock" you have (given bore size, piston material, piston-to-cylinder clearance, rod material, head style, head gasket bore dimensions, etc). For a purpose-built race engine one can tune the clearances to smaller numbers - though you need to consider all the details to do so.
    chicken and rod1 like this.
  17. sunbeam
    sunbeam
    I shoot for zero and use .040 head gaskets,
    Unkl Ian and lumpy 63 like this.
  18. lumpy 63
    lumpy 63
    Just a word of caution before you zero deck... Make sure your mains are all good and true before you take your measurements ... Because if you don't and you align hone it the pistons will be outa the hole if you want to or not.
    deathrowdave likes this.
