any olds rocket gurus?
Discussion in 'The Hokey Ass Message Board' started by mykwillis, Apr 18, 2008.
  1. mykwillis
    mykwillis
    what can you tell me about this motor? yr, size, value? common problems?
  2. Stevie Nash
    Stevie Nash
  3. mykwillis
    mykwillis
  4. Anderson
    Anderson
    I know where you can drop it off...
  5. Crafty
    Crafty
    from UK
    I'll take a guess at a '50-'52 303. From '53 the rocket emblem was stamped in to the rocker cover, 53 and I think 54 had flutes in each end of the rocker cover, by 55 they were plain.
    There is alot of olds rocket information here, try searching for "rocketeers"
  6. Paul
    Paul
    Editor
    you will need to run the numbers to pin it down
    but looks like a '49-'50 303 to me.
    only worth what you are willing to pay for it... or sell it for..
  7. d2_willys
    d2_willys
    from Kansas
    agreed on all counts:eek:
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    Think that carb was only on 49-50. 51 I had in 61 had a regular style 2 BBL
  9. mykwillis
    mykwillis
    i picked it up dirt cheap and figured out what was wrong with it. the builder who rebuilt it broke a head bolt while ***embling it. he let it go like that and the head gasket didn't seal so it got water in the oil.
    the old man was pissed so he just pulled it and put a small block chevy in it. this thing is NICE!
  10. mykwillis
    mykwillis
    i got the ****** off, put it on the stand, and blew it off and heres what it looks like.
  11. mykwillis
    mykwillis
    the number on the back of the block is 555641
  12. chaddilac
    chaddilac
    I'll give you $50 and pick it up...
  13. mykwillis
    mykwillis
    hell, i'd be taking a 25 dollar hit on it. :D
    i got a good ****** with it too. the only things i didn;t get were one of the valve cover covers and the yolk for the output shaft on the ******.
    this thing had like 30 converter bolts!
  14. CGkidd
    CGkidd
    Gotta love the hydromatic taurus. Looks pretty nice. Like Paul said 49-50 303 olds. The engines are pretty damn strong. If you want more info look in the tech area. The easiest way to hop it up is to get a set of 56 olds #10 heads and rockers. Read the thread on olds rocket engines for more info.
    Eric
  15. mykwillis
    mykwillis
    my guess so far is 49-51 i think in 52 they moved the generator to the p***. side. any ideas on that?
  16. junkyardjeff
    junkyardjeff
    49 or 50,I had a 51 years ago and it had a different carb. Jeff
  17. mykwillis
    mykwillis
    thanks man! i'm narrowing it down! the block numbers came up as 49-?. so i guess 49-50 it is.
