I am trying to find out if 1950 Chevy door sill trim, w/ body by Fisher tags, is the same as 1950 Oldsmobile. The car in question is a convertible so I would assume the Chevy sill would have to be from a convertible also. Does anyone know if the two are the same or not? Thank you! -Brian
Do you mean exactly the same, or interchangeable? If the Olds is an 88 they will interchange. (Pontiac, too). But only a diehard Olds fan will be able to tell you if they look identical. I can tell you that convertible and hardtop are the same.
That's what I was looking for. I did mean interchangeable with "close enough" looks to get away with it. Thank you for the information.
