any one have an old Jahn's Piston book
Discussion in 'The Hokey Ass Message Board' started by dalesm, Apr 15, 2012.
  1. dalesm
    dalesm
    from waterford
    Dose any one have a old Jahns piston book? I have a set of pistons and want to know what they fit.
    Box has Jahn's Racing pistons, 8-1105-h-rp-std
    2 1/64 def 4 1/8. it also has oldsmobile on the side of the box.
    Can any one tell me engine size and compression ratio? I think it is a 371 Olds
  2. Deuces
    Deuces
    Got calipers???.... Check the od and compression height from the wrist pin centerline....
  3. dalesm
    dalesm
    from waterford
    4.125 bore, compression height 1.890 plus .275 half dome
  4. landseaandair
    landseaandair
    from phoenix
    8 probably stands for no. of cylinders and in one of my old catalogs it lists 1105H as: 1957-58 Oldsmobile V8-high compression with 21/64 deflector
    bore sizes 4, 4 1/16, 4 1/8
    compression ratios 10.5:1 57, 11:1 58
  5. pauls fords
    pauls fords
    I got this info out of my first Jahns catalog and never forgot it Bore x Bore x Stroke x .785 x number of cylinders= cu.in
  6. dalesm
    dalesm
    from waterford
    Thanks for the info.
