Any pinstripers on here ever try and reproduce the double line on the Ford wheels?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 7, 2005.
  1. Roothawg
    Roothawg
    Any pinstripers on here ever try and reproduce the double line on the Ford wheels? Just wondering how big of a job this would be for a striper?
  2. brandon
    brandon
    i know there are guys that can do it......a buddy and i figured on a fixture to be able to rotate the wheel with out jerking it around as you spin it.....its not as easy as it would seem .......spin a wheel , hold a brush ....and hope the lines end up meeting ......hahaha brandon
  3. Elrod
    Elrod
    I've heard of people jacking up the car and spinning the wheel while holding the brush with some kind of jig. Also heard of people putting the wheel on some kind of turn table and doing the same thing.
    maybe using one of those Beugler Striping tools they sell at swap meets or on the web might be the trick to maintaining a line with a uniform width.
  4. davidvillajr
    davidvillajr
    don't know if it works for your application, but if they are concentric around the perimeter, you can use an old recordplayer/turntable and a bucket or paint can, I think.
    put the bucket or can on the record player, put the wheel on the can, turn on the record player, paint your stripes.
    I saw this on one of those cl***ic car rebuild shows on DIY network or something. They were restoring a cl***ic Packard and used the above mentioned technique.
    try their website, you may get lucky
  5. MikeO
    MikeO
    from MI
    Ive done it on motorcycles with a brush just by spinning the wheel ,It has always seemed to work
  6. SUHRsc
    SUHRsc
    i've done it on bicycle wheels...around the rim and hub
    theres always a guy at hershey selling something that clips in the center of the wheel to hold one of those roller striper tools that seems to do a great job
    good luck
    zach
  7. pekka_wizzz.
    pekka_wizzz.
    from Finland
    Done a few of those, these in the picture are from LaSalle, but the basic idea works on Ford as well. The biggest problem tends to be the unbalance of the wheel. No matter how smooth and nice a wheel is, there's always a slight unevennes found somewhere. The brush is the best way to find them, when there's a lump on the surface the line gets thicker and when there's a hole it gets thinner. Be sure that the painted surface is perfect, any imperfections will spill the line.
    You need some kind of rotating thing under the wheel itself. It can be a piece of plywood with a bearing attached to a table or sometimes the axles may work as well. The paint must be very thin, and the brush must have quite long hair fully soaked with paint.
    You can try to spin the wheel with your other hand and when the wheel spins nicely, not very fast though, you just lower the brush and let it touch the wheel gently. You propably have to wipe the paint off a couple of times before the line is nice but eventually it works. Best is to have a friend to rotate the wheel.
    Good luck!
    - Pekka
  8. Crusty Nut
    Crusty Nut
    I have done it to a wheelbarrow by spinning it (don't ask) worked out just fine.:D
  9. Paul
    Paul
    Editor
    I tried it
    but I'd rather not talk about it.
  10. Doc.
    Doc.
    The beugler is the way to go here. Just put the guide on the rim and pull. It has heads with different size single and double lines so you can pretty much get any width stripe you want.
    Doc.
  11. i had it done on the wheels shown here ( in the picture it looks like one wide one, but is actually two narrow ones) the guy had an electric motor on a turn table to turn them real slow and then just held the brush by hand
  12. TagMan
    TagMan
    I made up a fixture for striping wheels that locates to the wheel's center hole. Old pics taken for a quick reference , but hope they're self-explanatory. The tapered wooden 'bung' accommodates different size holes and the linkage allows placing wheel stripes anywhere you want 'em pretty quickly.
  13. Django
    Django
    from Chicago
    Tagman, what is laying down the paint?
  14. TagMan
    TagMan
    Sorry - I'm not the best 'splainer in the world :(
    The gl*** bottle, in the lower, right-hand corner of the first pic, is a el-cheapo pin striping rig from J.C. Whitney and it works great. There's a serrated wheel on the cover that picks up the paint from the bottle and lays it down on the wheel like a Beugler striper.
  15. Roothawg
    Roothawg
    I have a buegler striper somewhere.....I may try building a jig like the one you posted. That's neat.
  16. Tagman:
    And you didn't post this as a Tech piece? What a GREAT layout!!! I might even have to make a modified version(with your permission of course)to use with a brush.Fantastic piece of work and simple too!!!
    Ray
  17. ponchoman
    ponchoman
    That's probably the way to go Root, don't think Rick could even do that without a jig.
  18. TagMan
    TagMan
    No sweat, safariknut - mi fixture, es su fixture :D
    I didn't post this as a tech article 'cause I didn't think it was that big a deal. I couldn't lay down a decent line to save my *** and when you're cheap like me, you improvise !!
  19. AV8Paul
    AV8Paul
    Here's Alex Olivera striping my wheels. He used my floor jack to support the wheel and then free handed the stripes while rotating the wheel. He would have prefered to do it with out the tire installed as the valve stem gave him some trouble initially, but that wasn't an option.
  20. HOTRODPRIMER
    HOTRODPRIMER
    I did this to the wheels on my 40 Ford sedan a long time ago and a ol' sign painter that did all the sign painting for Coke Bottling co. here in Anderson striped the wheels on their trucks along with all the lettering,,,
    He clued me in on his way of painting the lines on the wheels,,,by mounting the wheel on an old spindle bolted to the wall in the shop he worked out of,,,,,
    That's the way I did it and I used a 00 mack brush and 1-shot enamel,,,,I wont say the first one was very good but by the time I did the forth,,,,I was ready to re-paint the first,,,,,,HRP
  21. 2manybillz
    2manybillz
    I'll second that motion.
