Technical Any piston manufacturer make a non standard wrist pin hole height?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Mar 21, 2024.
  1. Kerrynzl
    Kerrynzl
    Mike,
    Speed-pro off the shelf L2252YF dome pistons would net 10.71:1 with 72cc chambers
  2. Budget36
    Budget36
    More CR than I want, but will see about milling them down.
    The ridge I have in the bores is (worst one) .001 with my 25 YO eBay DBG.
    Now I need to clean up the rod/pton****embly and check the deck.
  3. Kerrynzl
    Kerrynzl
    They are a .200" solid dome , so they can be milled back [or use a thicker gasket]
    or Just use a fatter cam to drop the cylinder pressure :D:D
    Speed-pro also sell off the shelf L2304F .100" dome pistons would net 9.71:1 with 72cc chambers
    Deuces, Desoto291Hemi and Budget36 like this.
  4. Ericnova72
    Ericnova72
    from Michigan
    Not exactly a high demand item, not much market....
    but the parts already exist....Eagle makes a crank, D.S.S. Pistons has 5.7" rod pistons or you can use aftermarket 5.85 or 6" or 6.125"rods with pistons originally spec'd for 350" or 383" strokers.
    It's all off-the-shelf stuff....
    Deuces and Budget36 like this.
  5. jimmy six
    jimmy six
    CP-Carillo and Ross have made me Custom pistons since Nick Arias passed away. All of the put the pin where l wanted them which was deck level because of available gasket thickness. They were all for racing and forged.
    Budget36 and Deuces like this.
  6. Deuces
    Deuces
    That would be a .030" over piston.....
    Budget36 likes this.
