Any problems running these parts on a 216?
Discussion in 'The Hokey Ass Message Board' started by sinner13, Oct 27, 2006.
  1. sinner13
    sinner13
    from Buffalo NY
    I am about to order the Offenhauser 2 carb intake and a set of the Fenton cast iron headers for my 216. Any issuses that I need to know about running these items together? Like fitment or some other problems?
    Thanks
    Will
  2. Terry O
    Terry O
    Flange thicknesses are different. If I remember right the Fenton's are thicker than the Offy. If you have access to a milling machine that's a perfect solution but most guys just grind the high side of each of the manifold mounting brackets so that a step is formed to compensate for the uneveness of the flanges. Been done by alot of people and will work fine with patience.
    Terry
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You may have to grind a relief on the underside of the intake to clear the top of the rear header--no big deal.
  4. russ whitaker
    russ whitaker
    If I remember correctly, I think the 216 had smaller ports than the 235-261, I beleive we used to blend the intake manifold ports to the head and some times swapped the head for a 235 head.
  5. russ whitaker
    russ whitaker
    Just callled a friend of mine and he told me he thought we just used the intake manifold with a 235 gasket set as is and some times swapped the head out for a 235, ran just fine,
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It would have to be a '41-'49 235 head from a truck--the car 235s had a different bolt pattern than a 216.
  7. sinner13
    sinner13
    from Buffalo NY
    Thanks for the info guys....as always, I appreciate it.
  8. v8minor
    v8minor
    You will have to take some of the fentons or the intake to make them fit.I think I have some photos in my photobucket site .
    And I welded up the clamps so they bolted down seems to work ok .
