Technical Any recommendations on a tubing bead roller?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Mar 22, 2022.
  1. Roothawg
    Roothawg
    I’m looking at buying an inside bead roller for tubing approx. 3/4” and up to 2”.
    I see a few that are sold by Jegs etc and they all look to be the same mfg. Reviews are so so. It won’t get used very often, but so would like to roll approx. .065” Aluminum or stainless.
    Looking for something somewhat heavy duty.
  2. Imwalkin
    Imwalkin
    from Tucson, Az
    I made mine from a video on youtube. made from modified wire crimpers. look up tubing bead rollers a couple of how to videos should come up.
  3. Harv
    Harv
    from Sydney
    I bought the Aeroflow tube bead tool in two sizes. ****ped out after two uses.
    Got a crowbar out and prised my wallet open, and bought a set from Graham Tool (US made, similar to the old Parker WW2-era ones). They make beautiful beads.
    Cheers,
    Harv
  4. Jmountainjr
    Jmountainjr
    I don't think is going to be bending 3/4" - 2" tubing by hand. Thinks he's looking for a wheeled tubing bender.
  5. Budget36
    Budget36
    I think he’s looking to make a bead on the end of tubing. I/e to help secure the tubing for a hose where a clamp is put.
  6. Budget36
    Budget36
    I’d thought if you had a bead roller, you could do the same thing with a set of dies made to fit in the small diameter tube, they should still make a bead in larger diameter tube, right?
    Or maybe you can’t insert the tube far enough?
  7. Jmountainjr
    Jmountainjr
    OK. I just made my own. Cut some rollers out on the lathe and made an adjustable holder. Based on the time spent, if this one ever wears out I would just buy one.
    Roothawg likes this.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I don't know if this will help, but I made dies for my bead roller to do this job. Perhaps It may inspire some reader to try it.
  9. jaw22w
    jaw22w
    from Indiana
    I made one a couple of months ago for a radiator hose connection. IMG_0884.JPG Used an old pair of vise grips. Couple times around and it gives a nice bead. Cost... about 15 minutes!
  10. Roothawg
    Roothawg
    Correct.
  11. I wanted one that would go down to 5/8". That eliminated using my bead roller. I made one out of a pipe tubing cutter. I found out that I needed both the inside and outside rollers to turn to do a good job. I haven't re-engineered it yet. It's on the to do list when I get down with the current project.
  12. seb fontana
    seb fontana
    from ct
    One I made a while ago cause I couldn't find one to buy.
  13. 49ratfink
    49ratfink
    wow... I never knew I needed one of those. :)
    rpm56, Blues4U and Roothawg like this.
  14. Roothawg
    Roothawg
    They are cool to have around if you like solid tubing. I like things sanitary and hate seeing rubber hoses, but they are somewhat of a necessity.
    49ratfink, Just Gary and Dan Hay like this.
  15. jimmy six
    jimmy six
    That is really neat. It would definitely make using 2 hose clamps on the emt conduit we use on our race car
    jaw22w likes this.
  16. jaw22w
    jaw22w
    from Indiana
    Thanks! It's not much to look at, but it does the job. Crude but effective! I couldn't do 3/4" but it would do anything bigger. Gives your grip a good work out.
    alanp561 likes this.
  17. Mr48chev
    This one only goes down to 7/8 -.75/22 MM but the reviews are good. Amazon.com: Furick K2 Manual Tubing Bead Roller : Automotive Three times the price of the one that Jegs sells though.
    The one like Jegs sells didn't get very good reviews except by folks who used it on very light tubing Amazon.com: Hiwowsport Tube Pipe Tubing Beader Tool Bead Roller Intake and Intercooler Piping Fits 5/8" : Automotive
    The Jegs unit Amazon.com: JEGS Tubing Beader | Fits 5/8 Inch and Larger Tubing | Beads Tubing Up To 0.050” Wall Thickness | Vise Mount Design | For Copper or Aluminum Tubing : Automotive
    There is also a Vibrant brand that has better reviews that may be the one that the others are knock offs from. Amazon.com: Vibrant Performance 2990 Manual Bead Roller (minimum tube diameter to be used is 3/4" OD) : Automotive
    On 3/8 and smaller tubing I just use the first die on my double flare tool and don't squeeze it down all that tight.
  18. gimpyshotrods
    gimpyshotrods
    I have been looking at the Furick K2.
    I can do Metric bubble flares with my hydraulic tool up to 1/2".
    That would leave out 5/8 - 3/4".
    I like to work with stainless at times. Not too sure that a cheap bead tool is going to be a good choice.
  19. Mr48chev
    Outside of fighting with bends for larger tubing I'd think that a set of dies for a regular bead roller and maybe fabbing a clamp on stop plate to but the end of the tube up against would work.
    The Furnic K-2 is interesting but that is getting into the price range where a tool has to have enough work to pay for it's self and is beyond the occasional use level.
  20. theHIGHLANDER
    theHIGHLANDER
    I have the best recommendation. Find a pal that has one and buy him a pizza for letting you use it...;)
    I only offered that cuz it worked for me.
  21. Dan Hay
    Dan Hay
    That's my plan for Root when he gets one.
    Just Gary, Roothawg and theHIGHLANDER like this.
  22. Roothawg
    Roothawg
    That's a big If partner....... It's looking like I need to befriend a tuner kid that is building a turbo car.
    49ratfink, theHIGHLANDER and Dan Hay like this.
  23. ratrodrodder
    ratrodrodder
    from Boston
    And if he chooses the $pendy one, bring some beer too! :D
  24. Jmountainjr
    Jmountainjr
    image0.jpeg Here is the one I made to use on some aluminum 1 3/4" tubing for radiator plumbing. My brother uses it on turbo plumbing. It has a tab to clamp into a vice.
  25. Blue One
    Blue One
    from Alberta
  26. BamaMav
    BamaMav
    from Berry, AL
    There are several home built ones on YouTube. I thought about building one, but for the few times I’d use it decided it wasn’t worth it.
  27. blue 49
    blue 49
    from Iowa
    I have one like this for larger tubing. I have a friend that has a very nice set for smaller stuff but it's not very handy to run down to his shop to use it when needed.
    Gary
  28. jimmy six
    jimmy six
    The Eastwood double flare tool can do up to 3/8” on fuel lines. It the water ones I need to do and the vice grip homade one will do it.
  29. Anderson
    Anderson
    I’ve usually had access to a bead roller with a set of dies to do this…but have never been able to get a good bead in stainless tubing. For stainless, I usually take a small strip of extra material and weld it around the outside of the end of the tubing, then chamfer the hard edges. Always worked really well.
  30. blue 49
    blue 49
    from Iowa
    I've made these "caps" for 3/8 and 5/16" tubing and use my flaring tool to do mine. They have a shallow, flat bottom hole with a chamfer that the tube goes into and a fairly deep countersink on the other side. Clamp it up with about a 1/16" gap under the cap and crank it down. If everything is square, it comes out pretty good. I didn't do it on this sample, but I buff the clamp area with a wire wheel and it looks pretty good and works.
    Gary
    Roothawg and Barrelnose pickup like this.
