Any suggestions on how to patch this?
Discussion in 'The Hokey Ass Message Board' started by HDVooDoo, Apr 15, 2008.
  1. HDVooDoo
    HDVooDoo
    from TEXAS MOFO
    This is the frame for 54 chevy truck. I need to patch the bottom portion of the frame, but not sure which way to do it. May thinking was cut it out,replace it, find a way to brace on the inside, then box the frame. Any suggestions?
  2. brokenspoke
    brokenspoke
    looks too far gone for my use..looks like the frame should have been repaired before the what ever bracket was welded...looks cobbled to me
  3. MIKE47
    MIKE47
    from new jersey
    You're gonna have to remove the whatever bracket (4-link bar?) first. Then you can cut out a temporary inside plate to hold the top and bottom flanges of the frame while you then cut out the rusted/patched outer side. Weld the new outer side only to the outer vertical frame area. Then cut out the top flange and replace that. Weld all the new outside and top together then cut out and replace the bottom flange. Weld that in. Once your all done you can cut the tacks off of the temporary inside plate and reattach the whatever backet properly. Boxing it in will add a lot of strength to the area but, can you do that with those bars or will you then have to re-work the other end of those also?
  4. HDVooDoo
    HDVooDoo
    from TEXAS MOFO
    I should be able to box in the area. I will have to leave a small opening for the nut and bolt though.
