Technical Any thoughts on overheating problem
Discussion in 'The Hokey Ass Message Board' started by spillaneswillys, Sep 8, 2015.
  1. Almost all of the bugs worked out on my 34 Dodge, changed to a 180 degree thermostat but car still gets to 240 on the gauge on the highway. Seems to be ok in town. Have a brand new aluminum radiator with an electric fan going the right direction. Any thoughts are appreciated.
    Joe
  2. squirrel
    We'll need a lot more details, and pictures would be a big help...several pictures, of the front of the car from a few different angles, including inside the engine compartment.
    volvobrynk likes this.
  3. What does your gauge read when you put the probe in a pan of boiling water? In other words, is your gauge accurate?
    Charlie Stephens
  4. pitman
    pitman
    Air-in, hot air-out.
    Pics of shroud(s)?
    Fan location?
    Exhaust type & routing?
  5. scrap metal 48
    scrap metal 48
    Shouldn't even need a fan at highway speeds.. Low on coolant, poor air flow through the radiator, air going around radiator???
  6. Gman0046
    Gman0046
    Remember the cooling "Rule Of Thumb". Runs hot at highway speed - not enough radiator. Runs hot at low speed - not enough fan. Looks like you don't have enough radiator.
    Gary
    volvobrynk, tb33anda3rd and sunbeam like this.
  7. themoose
    themoose
    Some Another things to look for is the water pump. It may not have the water flow capacity to keep your engine cool or the impeller itself is slipping on the shaft and not moving the water it needs to move. If your using aftermarket pulleys its possible that the water pump and/or the crank pulley is the wrong size which can slow down the speed at which the water pump is spinning and pushing water. Another thing to look for is the lower radiator hose. The lower hose should have a spring inside of it. This is because the bottom hose is the suction side where the water pump ****s water out of the radiator and pushes it through the engine. When the spring is removed or it simply rusts and disintegrates, this leaves nothing to prevent the hose from collapsing under the suction of the pump. If the hose ****s closed, it cuts-off the water supply to the engine. Sometimes the spring inside gets ****ed-up inside the water pump inlet a few inches, which exposes a few inches of lower hose to be vulnerable to being ****ed closed, especially after the engine has warmed-up and the hoses become even more soft and supple.
  8. Jalopy Joker
    Jalopy Joker
    fan in front of radiator? just running electric fan? if metal fan, is it in the middle of radiator? automatic trans cooler in front of rad? have A/C? what kind of motor?
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Iginion advance working properly??
  10. HOTFR8
    HOTFR8
    Interested to follow this as I had a heat soak issue and solved it by adding a by p*** with an electric water pump.
  11. rodnut
    rodnut
    from indiana
    question ! if using a high flow waterpump and a performance radiator is it possible that at higher rpm the coolant isn't in the radiator long enough to cool properly
    da34guy likes this.
  12. wraymen
    wraymen
    I was wondering the same thing. I believe the difference in temp. would be negligible. Even though coolant would be in the radiator for a shorter time during a cycle, it would cycle more times under operation and should at least even out or as I see it, provide more cooling.
  13. Ask the guy about damage from operating engines with overly extended time to reach operating temperature.
    Ask the guy about the combustion process when cylinder temps aren't where they need to be.
    Removing the thermostat has always been a bad idea, it will take longer to warm up, longer to reach full operating temp, but then its double quick to over heat. Maybe buying that time masks a problem long enough to get to grandmas house, and that's all you really need but the trade off is driving an engine that never lives up to its performance potential and dies a quick death.
    The idea is to maintain cylinder temps at optimal range. The thermostat does this by allowing the cooling process to begin. It establishes a "do not exceed" set point while allowing faster warm up to that optimal set point. It's really neat. Everything works flawlessly unless the generation of heat surp***es the ability to shed heat. The radiator must be able to shed heat faster than the engine can make it or eventually a over heat condition will result.
    pitman and 69fury like this.
  14. Gman0046
    Gman0046
    Forget the BS about water not being in the radiator long enough to cool it. That theory is contrary to every law of physics yet it continues to be inserted on every thread related to engines running hot. Its pure and simple Bull ****. If that statement was even close to being true, why would anyone manufacture and sell a high flow water pump much less anyone buy one.
    sdroadster likes this.
  15. You do know that temperature change equations require a time factor right. There's no way to do one without knowing how long of a period of time the heat has to migrate to the cold. The greater the temp difference the faster it goes.
    Place 2 objects one hot and another cold together for 0.00000001 second and note the temp change. Do it again for 10 seconds and again for 30 second.
    Of course this is ******** too and contrary to physics.
    Heat leaves, cold never enters.
  16. I had a similar problem with a '57 T-bird. Ran hot on the highway but ok at "in town" speeds. I tried everything I could think of, thermostat, radiator work, timing. Finally turned out to be a busted diaphragm in the distributer. I found it because I noticed a pulsing of the power at "in town" driving speed. Not very common but keep it in mind.
    Charlie Stephens
  17. unkledaddy
    unkledaddy
    The first thing I would do is make sure that the 240 degrees is accurate, using a tested
    mechanical gauge or a non-contact themometer.
    You should be able to smell "HOT" at 240 degrees at shutdown.........then try and
    restart it. At 240 it shouldn't start easily if at all.
    I tried two hi-flow water pumps and both behaved exactly like you (the OP) described. Once I replaced them with a OEM pump the temperature has been perfect.
  18. yes, removing theromstats is a bad idea, I ran my Y block the first winter without a T-stat and it would warm up slowly and run abouy 150*. The problem is, that I would get alot of condensation in the breather cap and dipstick. I even had to wipe out water drops from inside the valve covers. I put in a 180* T-stat and no more condensation problem. also the car does not overheat.
  19. abner36
    abner36
    all great info here but we need more info , any engine, ****** specifics, makes a big difference in helping, timing , carb tuning , engine speeds at highway speeds all make a difference. need more info
  20. Petejoe
    Petejoe
    from Zoar, Ohio
    31Vicky makes a very good point. But flatheads heat up very fast without a thermostat. If they were run during cold winter conditions. I'd agree with him totally. From my experience running flatheads I've had great results with high volume pumps, no thermostat, a 4 lb cap, and a pressurized system. Of course a clean block, correct advance and proper fuel flow is first in the list. Yes, verify your gauge reading with a temp gun.
  21. rodnut
    rodnut
    from indiana
    great point unkledaddy !we really don't know if there is an overheating problem it could be a wiring or gauge problem
  22. donno
    donno
    Just my 2 cents, but I would check the temp gauge for accuracy as mentioned AND the sending unit. Does it (sending unit) have any sealant or Teflon tape on it? Where is the sending unit located?
  23. I am sure he has already checked it as I mentioned it in post #3. Funny we didn't get a report on the results, I ***ume he read it. It is sure nice to get a report so we can scratch the item off of the list.
    Charlie Stephens
    unkledaddy likes this.
  24. 69fury
    69fury
    from Topeka
    Post pics and specs-be VERY detailed. Including the history of the engine and heads- I had a 360 mopar that overheated only on the highway- head had a crack by the exhaust seat. So IF IF IF the specs of your cooling system check out, it could be something along those lines.-rick
  25. I want more BS physics lessons. :D
    Or pointers at how to cheat at physics and win:p
  26. sunbeam
    sunbeam
    Is it puking coolant at 240 it should be unless you have a very high pressure cap?
  27. pitman
    pitman
    31Vick,
    You just got too many dynes per erg!
    Or was it kilowatts per ft-lb? :(
  28. Yes
  29. I don't know much about your car but when I have one that runs cool around town and gets hot on the highway I usually drill a few small holes ( like 1/8 or 3/32) around the perimeter of the T stat and that usually cures it.
    i.rant likes this.
  30. mgtstumpy
    mgtstumpy
    I've seen similar year cars run hot because of no apron under radiator to direct incoming air through the radiator. Air just blows through gap underneath and not through as designed.
