any tips /help for awesome brake pipe bends etc
Discussion in 'The Hokey Ass Message Board' started by steveo3002, Aug 16, 2013.
  1. steveo3002
    steveo3002
    from england
    i can do okay with brake pipes , but they dont look 100% perfect always a bit home made looking , id like to do better show car standard stuff
    any tips on making the bends and shapes etc (ive got a good flarer so no probs there)
  2. A tubing bender makes nice tight bends and wont kink the brake line
  3. Xtrom
    Xtrom
    from Forman, ND
    As with any tool get a good quality piece. Not the $10 tool they sell at most chain parts stores.
  4. chopolds
    chopolds
    from howell, nj
    Best thing I ever came up with for bending tubing: take a spare piece of tubing, about 4 in long, use a tubing cutter to scribe a line on one end, about 1/2" in. Now, put that line on the "Zero" marker of your bender, and make a 90* bend.
    You use this piece to hold next to tubing you have run to see EXACTLY where you need to put your bend, transferring the scribe on the test piece (with a pencil) to the 'real' tubing. That way the bend is always precisely where you want it.
    I've got a set of all the usual sizes.
  5. gasserjohn
    gasserjohn
    start with straight tubing not rolls
    use an fittings use tools by rigid
  6. BillM
    BillM
  7. 41GASSER
    41GASSER
    Take your time and use quality tools. Brake line is cheap so if you mess up just throw it away and make a new one. Get a quality flare tool and double flare the ends.
  8. reefer
    reefer
    Cheapo way to get tight bends at the ends......get a six inch nail and cut the ends off, solder a male fitting to one end and a female to the other......this can now be used to screw into the fittings on the brake pipes and introduce a nice tight bend either using your thumb of find a piece of tube or something to use as a former.The extra leverage from the "tool" makes it easy and you can use it in places where it would be difficult to get a bender set in.....3/16" is virtually impossible to kink.
  9. bt34
    bt34
    These are awesome for tight bends..Came from a brake supply shop somewhere in the USA..Around the 30 - 40 dollar mark..expensive but good. No brand.
