Technical Any tips on using a shrinking disc?
Discussion in 'The Hokey Ass Message Board' started by ABONES, May 17, 2016.
  1. Searched and found some threads about which disc to use but I'm looking for any tips or advice on how to use one. I have a back of a model A pickup cab that's going to need some shrinking. Its mostly surface rust. Should I sandblast it before I start working it. Tips? Techniques?
  2. rod1
    rod1
    Yes , sand blast it first,Then knock down then rough surface of the blasted area with 80 grit on a DA or you will wear out your shrinking very Quickly.Make sure you have ear plugs on.If you have a Sunchaser style,Be careful of the edge as it will rip you open leaving scars for the rest of your life.
  3. I think there are some youtube videos of 'em.
    I love mine, but x2 on the earplugs and gloves. My wife calls it "the shrieking disc of flatness". :eek:
    Johnboy34 likes this.
