Any tricks to grease stubborn front end fittings?!?
Discussion in 'The Hokey Ass Message Board' started by Johnny1290, Dec 28, 2010.
  1. Johnny1290
    Johnny1290
    The caps on the zerk fittings is brilliant.
    I've been replacing zerks that didn't grease...on the faint hope it might make a diff. No dice usually, unless a different angled one makes it possible to get the gun on there.
    I can see I'm going to have to get serious about this to get the car to grease.
    The front end bushings misaligned? Considering how much I paid the monkeys at the machine shop, and how long they took, well, of course they were installed wrong. God.
  2. jrlemke
    jrlemke
    Be careful with the heat, I heated the kingpins on my 68 Chev van and then found out that the kingpin bushings were nylon! Check before heating!- Jim
  3. tjet
    tjet
    I missed it, calm down.
  4. Roger O'Dell
    Roger O'Dell
    I have a little trick that works for me, I use a hand grease gun, I have a 12 inch rubber hose on it. I remove about 6 inches of grease from the hose, then fill the hose with kroil (penetrant). Then pump the kroil into the grease fitting when pressure is built up I wait a little while, then pump pressure back up, and so far have been lucky. Roger
  5. rainhater1
    rainhater1
    from az
    Had one broken off flush, couldn't get it out. Drilled a new hole and taped it. New zerk and it took grease like new. ran a lot through it to clear anything left over
