Technical any Weber carb guys out there??
Discussion in 'The Hokey Ass Message Board' started by birdman1, Jul 16, 2024.
  1. birdman1
    birdman1
    I always THOUGHT I wanted to run Weber carbs, so I bought 4 of the IDF 48 . I had to make a adapter to bolt them on to my engine. I don't have any vacuum leaks that I know of, but the engine will only idle at about 1,000 RPM after it is warmed up. I read a bunch of stuff from Redline about the webers, and is a great help. I do know I need to re-think the throttle linkage as it is not precise enough the way it is now. Thanks for any help. See you at Bonneville!
  2. Joel W
    Joel W
    I'm no help, but I'll see you at Bonneville! Joel Wahling in Shelby
  3. Oneball
    Oneball
    Disconnect the linkage from all carbs
    Screw the idle screws all the way out.
    Loosen the nuts either end of the throttle shaft then push the throttle blades open with a stick and let them snap shut.
    Then do everything up and reset the idle. Be careful when you do the nuts up not to end up with the ****erflies slightly open.
    If that doesn’t work you’ll need to check the ****erflies are actually closing all the way with the idle screws wound out.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Be interested to see the " adapter" you made?
    I don't know if Inglese is still in business , they know webers
  5. Bandit Billy
    Bandit Billy
    There are 2 types of weber 48's, those that run well and those that don't. I have a pair of 48s that fit in the latter category. @Oneball is correct on disconnecting the linkage, turn out all of the idle screws and confirm the ****erfly's are closed. They are simple designs but I have been close to tearing them off my buggy and going for a single 4 bbl.
    mad mikey likes this.
  6. birdman1
    birdman1
    The main problem is the idle. I have the pressure regulator set at 3#. Is that enough? I will take a picture of my "home made adapters" soon.
  7. Turns
    Turns
    As above and could be idle jets. To get the correct 'mix' of jets and emulsion tubes can be tricky.
    Any vacuum leaks?
    rockable, 2OLD2FAST and mad mikey like this.
  8. rod1
    rod1
    Try 2# . Do you have a return line going back to the tank? I ***ume you have a synchro meter for the air?
