anybody else build a big truck
Discussion in 'The Hokey Ass Message Board' started by Jarred Hodges, Dec 6, 2009.
  1. Jarred Hodges
    Jarred Hodges
    I have a 1949 F-5 that I would like to get going. It has a flathead v8 4spd. I would like to put a car hauling bed on it to haul my racecar and other cars. I plan on trying to get the flathead going but if I can't it will get another engine put in but I am not sure what. I got this about 5 years ago for $125. I haven't messed with it much but will after the 51 is finished
  2. Mine is bigger than yours:D!
  3. inliner54
    inliner54
    here is mine[​IMG]
  4. bobj49f2
    bobj49f2
    I have a '48/51 F-4 that I like to say is half done. I have a lot to do on it but I just got a '37 Buick project that I think I might get road worthy by the spring.
    You might want to read this post on my web site:
    http://fatfenderedtrucks.com/widowmaker.html
    Inlaw, where are you locate, sorry if I've asked you this before.
  5. firemancooter
    firemancooter
    Is that Santa I see driving the firetruck?
  6. Yea, the reindeer must be on strike. The truck is lit up for x-mas in my front yard.
  7. I'm building a '59 F-350 1 ton dually to pull my 4 car wedge trailer for long trips and many, many miles. I stretched the frame at the cowl and put in a '96 ***mins turbo with 6 speed trans, 70s era Dana 70 rear and disc brakes on front. I plan to use it a bunch.
    I am also on the lookout for some mid-late 50's GMCs, 1 ton or more, that were powered by Pontiac V-8s for my collection.
    Steve
    Hosting-
    Sunday April 11, 2010 8th annual Nostalgic Show & Go! Phoenix www.nostalgicshowandgo.org
  8. OldSub
    OldSub
    I'm building a '54 GMC 1-ton, which isn't as big a truck as the Ford F-5.
    5-window cab. GM 14-bolt rear. Cadillac 500 with TH400. C20 disk brake IFS. I'm building it to pull my tandem axle car trailer.
    I have two cabs to choose from, one of which is my avatar to the left. The alternative is essentially the same, but currently a different color.
    Check out the threads here on COE trucks. Any GM COE will be a 2-ton or larger truck.
  9. Hemi Joel
    Hemi Joel
    from Minnesota
    After I saw the AC Mack at the Peterson Museum, I thought it was so cool I just had to have one. So I found this one, bought it, fixed some stuff on it.
    Then reality set in. It took up more space in the shop that I could spare. It was too slow to drive anywhere. It was still cool, but I sold it.
  10. Ghost28
    Ghost28
    We picked up a complete 41 chevy beet truck with a tilt bed, awhile back and was thinking car hauler also.
  11. I've got "restfied" '57 F600, 292, 5 speed OD, 2 speed rear flat bed.
  12. These are mostly from a show in Macungie, PA about 12 years ago. Only two Hot Rods, but damn cool trucks none the less. Sorry for the b/w, but I was shootng for a special project.
