Hot Rods Anybody Ever Use A Fan Powered Trans Cooler As a A/C Condenser?
Discussion in 'The Hokey Ass Message Board' started by davvet2, Dec 17, 2023.
  1. davvet2
    davvet2
    Curious if anyone has ever used a fan powered trans cooler as a a/c condenser.
    Since most of the trans coolers I've seen are so much smaller than a/c condensers, just wondered if it would work. If it would work, that would allow me to mount the trans cooler in another location other than in front of the radiator.
  2. BJR
    BJR
    They make remote condensers with fans, do a search.
    pprather likes this.
  3. rockable
    rockable
    It won't work well enough to satisfy the temperature demands of Central TX, if at all. If you're going to try something, mount a condenser elsewhere and try an electric fan on it.
    jaracer likes this.
  4. okiedokie
    okiedokie
    from Ok
    Not if you want an A/C that works.
    jaracer and badshifter like this.
  5. davvet2
    davvet2
    Thanks guys, that's what I needed to know. The remote 1217 a/c condenser that Southern Street Rods sells looks like the one to use.
  6. 325w
    325w
    Just remember how much pressure is in an ACsystem
  7. pprather
    pprather
  8. A transmission cooler will not have nearly enough capacity to act as a/c condenser. As 325w pointed out, a transmission cooler will not withstand the pressures found in an a/c system. High side pressure on a hot day could easily reach 350 psi.
