Anybody have pics of their homebuilt frames?
Discussion in 'The Hokey Ass Message Board' started by Diehard32, Nov 23, 2009.
  1. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    That frame is sick
  2. sniperfab
    sniperfab
    Here are some rails that i am in the process of making for my 1927 coupe.
    [​IMG][​IMG][​IMG]
  3. 53sled
    53sled
    from KCMO
  4. Tim morrison
    Tim morrison
    Here's mine.
    :confused:I just bought two sticks of 2x3 tubing and the front and rear cross-members, started cutttin, welding, grinding and cussin' it's nothing fancy but it was a blast to build.:cool:
  5. Slag Kustom
    Slag Kustom
    31 a pick up ive been building forever
  6. onlychevrolets
    onlychevrolets
    damn fine job....I don't know what you do for a living , but I know what you could be doing.
  7. 53sled
    53sled
    from KCMO
    My bud in Tulsa has one he made for his 37/8/9 chevy truck cab in a thread on here somewhere,
    start
    update
    and here is a nice thread with links to other guys chevy truck projects for inspiration
  8. langy
    langy
    Thats a lot of nice work Sniper.
  9. rcderocher
    rcderocher
    Check out my album for more pics. I still need to ****on up the front end. Trying to get the front cross member worked out.
  10. onlychevrolets
    onlychevrolets
    where did you get that piece of steel for that table??
  11. jdsludge
    jdsludge
    I built this for my "35 International C-1.
  12. 32 hudson
    32 hudson
    Frame for the coupe in my avatar
  13. jazz1
    jazz1
    Keep the pics coming,,i have to either modify the frame I have or build one using 2x4 square stock...I think it would be easier if not faster to build than to modify and box the 42 K2 I have,,,it's got some rot and maybe a bend in the rear
  14. Here is pictures of mine. Not real fancy, but it works for me. 2x4 tube model A front
    cross menber, & rear kick up.
  15. Wayne C.
    Wayne C.
  16. TomWar
    TomWar
    Here's a few Pics of the frame for my Roadster.
  17. flthd31
    flthd31
    Here's some pics of a frame and rails I fabbed a couple of years ago. The rails were made from .125 flat cold roll. Here's a link to the details on construction for those who missed it.
    http://www.jalopyjournal.com/forum/showthread.php?t=299105
    The car is done and is torn-down for finishing (fun stuff is over!) The front radial tire are just temporary.
  18. 117harv
    117harv
    HPIM6291 (Small).JPG HPIM6276 (Small).JPG HPIM6290 (Small).JPG HPIM6285 (Small).JPG HPIM6272 (Small).JPG HPIM6282 (Small).JPG Here are some pics of a ch***is that i'm finishing up for a customer. The ch***is still needs body mounts as well as the steering box, and is for a 29 Desoto sedan.
    The wheels and tires were purchased from a fellow HAMBer by the customer in Sacramento, don't know their name.
  19. metlmunchr
    metlmunchr
    Real nice work Harv!!
  20. resqd37Zep
    resqd37Zep
    from Nor Cal
    Almost too bad you have to cover this one up with a body. Thats a beauty.
  21. Lucky77
    Lucky77
    Here's a pic of the frame that's under my sedan right now. I just made a little ch***is table recently so I could build a new one. Might slip it under my sedan or save it for another project. I wanted to try my hand at sweeping and pinching a ch***is and it turned out pretty good.
  22. Von Buzz
    Von Buzz
    from Minnesota
    model A frame I built about 20 years ago,for a customer.stock mustang 2 stuff up front,80s malabu 10 bolt with stock 4 link arms. brake ,fuel ,trans. lines run inside the frames tubing. stainless fuel tank under p***. side,battery, brakes under drivers. frame is same hight as running board skirts.The body also got a lot of steel reinforcement .a little bit heavy ,but solid as hell. Dave, the owner, has around 30 thousand miles on it since I built it. Its held up well. He finally got better looking wheels for it,so were going to re do the flames in more traditonal colors, maybe pearl white into candy orange , do the rims orange too. Old Buzz Pics141.jpg
