Technical Anybody know this bolt
Discussion in 'The Hokey Ass Message Board' started by 29plymouthroad, Mar 17, 2024.
  1. noboD
    noboD
  2. Sharpone
    Sharpone
    No that’s where I got my measurements from they have their place - no sharp edges to catch stuff etc. only use a high quality hex wrench to avoid stripping the hex I use proto , eklind and bondhus wrenches, never stripped a hex.
    Dan
  3. vtx1800
    vtx1800
    If you were in the midwest you could go to Bomgaars a "sorta" farm place like Tractor Supply and they have a huge selection of that type of hardware, you may have something like that on east coast??
    Sharpone likes this.
  4. hoop
    hoop
    Try Bolt Depot in Hingham Ma.
  5. LWEL9226
    LWEL9226
    from So. Oregon
    no....
    LynnW
  6. ekimneirbo
    ekimneirbo
    I usually buy longer ones and then screw a nut or two on the threads to get slightly more length than I need. Cut it off with a hacksaw or bandsaw and dress the end slightly on a belt sander. Screw the nuts off to make sure the thread isn't burred and you should be good to go. Personally I like the Torx head versions the best .
    Go to Amazon and type in "Torx Head Screw". It will come up with a chart that you can look at ....shows many forms of screw heads as well as drive types. There are a bunch of similiarly shaped but different head styles and the names for them. ****on Head is one design, but there are a bunch of those similar shapes that may be of interest to you and others for future reference. Check out the "modified truss" type. They even have a "two headed" screw............:D
    Sharpone and Tow Truck Tom like this.
  7. ekimneirbo
    ekimneirbo
