Anybody know what brand these Torq Thrust type wheels are?
Discussion in 'The Hokey Ass Message Board' started by stovebolt55, Jul 30, 2012.
  1. stovebolt55
    stovebolt55
    Anybody know exactly what type of wheels these are? I'm trying to find some matching 15" versions and I'm not exactly sure who made these.
    They're supposedly not American Racing because I've learned they will say "American Racing" on the back of the wheels if they're the real deal. These have a rough texture to the spokes.
    Maybe U.S. Mags?
    Sorry for the crummy images, I took the pictures with my phone.
  2. LANCE-SPEED
    LANCE-SPEED
    My guess would be og (1960's-ish) American Racing
  3. 333 Half Evil
    333 Half Evil
    Was there an ET wheel like that with the darker rough cast centers? I'll have to try and look through my junk, I'm thinking I have some like that and I'll check to see if any for of ID on the back side. Do yours say anything anywhere on the back side? Look closely at the inside of the spokes, some of the ones I've seen have ID or info cast into the backside of the spokes....
  4. MATACONCEPTS
    MATACONCEPTS
    Vintage Torq-Thrust are staight spoke. In the mid/early 60s is when they added the "D" "Torq-Thrust-D" for Disk breaks which have curved arms for the calipers.
  5. Look like ETs to me.....here's a set [polished] on my old 49 ford.
  6. Could be old Keystone mags. HRP
  7. Tinman
    Tinman
    from Orange, CA
    So many companies made versions of the Torq-Thrust wheel that they're difficult to positively ID without some more clues. Clean and inspect the back of the wheel for a manufacturer's name or model name/number... look specifically inside each spoke and around the perimeter of the hoop.
    Also, you can research (google image) vintage wheel advertisements to get a feel for the hallmarks of each brand... like spoke shape, window size, hub size, machining/reveal profiles, lug type, etc...
    Good luck! Wheels are fun...
  8. Mopar Jack
    Mopar Jack
    Some kind of knock off...
  9. stovebolt55
    stovebolt55
    If you look closely, they have a little edge machined where the spokes meet the rim. I noticed that the new U.S. Mags they are making also have that little ridge. (They are modernized in other ways)
    I haven't seen that ridge on any of the wheels I've found online.
    I don't think they're ET's or American Racing. I will inspect them closer for any mfr info, but I didn't see anything.
  10. They look like a Old set of Ansen Mags
    I could be wrong
    but its just a guess from the 60' or 70's
    just my 3.5 cents
  11. 40 & 61 Fords
    40 & 61 Fords
    I'd say they're AP.
    That stood for Appliance Plating I believe. They were made in Japan, and are condsidered one of the better torq thrust copies.
  12. Stroker McGurk
    Stroker McGurk
    from Canada
    Look like the ETs that I have....thick spokes and mounting flange
  13. Deuces
    Deuces
    I like the Fenton 5-spoke...
  14. Black Panther
    Black Panther
    from SoCal
    Theyre probably US Mags or Rocket...they were torq thrust copies sold by JC Penneys, Sears..etc..aluminum American Racing torqs thrust mags were always branded...I believe Ansen and Fenton were always branded too...Appliance had recessed lug nut holes which these dont have, they would also have Japan cast somewhere on the back....
  15. ewob53
    ewob53
    from Minnesota
    I got a set on my OT Biscayne that are dead ringers for those. Never knew what kind they were, but they are stamped "Japan" on the back. No other stampings.
  16. 327-365hp
    327-365hp
    from Mass
    I believe stovebolt55 is correct. U.S. Wheels made them with that sharp edge around the mounting hub. Not that it matters though. When you're searching for 5 spokes everyone calls them Torq Thrusts.
  17. stovebolt55
    stovebolt55
    I haven't found "Japan" cast anywhere on them, I looked for that but didn't see it.
    Sounds like they may be US Mags, Fentons, or Rocket.
    They came on my '56 Chevy and I believe they were on it for several decades.
    If I could just find 2 15" wheels to match these 14" fronts I would be a happy man.
  18. The earlier appliance were made in Cal .... later Japan and the later ones say "JAPAN" in caps .... pretty sure you got some appliance ..... I gots 'em on my 59 bisquit.
  19. stovebolt55
    stovebolt55
    Do your appliance wheels have that little ridge where the spokes meet the rim?
    If you get a chance, would you please take a picture?
    Thanks!
  20. 3340
    3340
    Yup I,m With Sam123
  21. My guess was off,,this is one of my early 60's Keystones. HRP
    These were on my 63 1/2 Falcon Sprint.
  22. Tinman
    Tinman
    from Orange, CA
    So you've clearly got cast 1-piece aluminum wheels, which helps to eliminate some of the composite steel/aluminum wheels like the Keystones HRP shows above.
    I think the key design element (from the front, anyway) is the taper of the hoop between the slightly rounded (but still straight) spokes... the way the window narrows from the face of the wheel toward the rear/mounting surface. They look very similar to these Fenton Hustlers... but I'm still not 100% sure.
  23. buckd
    buckd
    Yea I've got a set of those on my wife's shoebox and like some of the other copys American center caps don't fit them (holes don't line up)BUCKD
  24. indianhead74
    indianhead74
    I had a set of ET's look up Wheel Centre Co. That had the gold painted spokes and thick flanges. Rod and Custom magazine did an article on the company in about '68-'69. Hope this helps. Indy
  25. 40 & 61 Fords
    40 & 61 Fords
    The vintage ET 5 spokes I have are uni-lug, and have ET molded right into the face of the wheel above one of the lug holes.
  26. Drive Em
    Drive Em
    They are not:
    -Torq Thrust
    -ET
    -Appliance
    -Fenton
    -Ansen
    They are most likely U.S. mags, as I have an identical set that I know are U.S. mags.
  27. Deuces
    Deuces
    This is a Torq-Thrust... ;)
    Pic was taken with a cheap cell phone.. :rolleyes:
  28. Thorkle Rod
    Thorkle Rod
    Got these for sale nice and cheap
  29. 327-365hp
    327-365hp
    from Mass
    I agree, I said it before but nobody listens. :confused:
  30. stovebolt55
    stovebolt55
    I believe you guys are correct, I'm now pretty sure they're US Mags,
    thanks for your help.
    Now, anybody have 2 US Mag Torq thrust copies for sale in 15x6 or 15x7 Chevy bolt pattern?
    Please PM me if you do.
    Thanks.
