Technical Anybody manufacture a bolt in 32 rear cross member
Discussion in 'Traditional Hot Rods' started by GregCT., Feb 23, 2014.
  1. GregCT.
    GregCT.
    from CT.
    Does anyone know of a vendor or fabricator who has a 32 Ford rear cross member available that is flattened for a new traditional build? Looking for a bolt in replacement type. Going with un-boxed rails. PM me. Thanks. G
  2. StrickV8
    StrickV8
    If you get a PM, please post here for others. Thx
  3. kb cookout
    kb cookout
    I don't know of any , But are you planning to use a straight rear spring or the curved 1932-34 style rear spring ??
    later kb
  4. thequietwon
    thequietwon
    El Polacko makes a nice one, but it has just a little bit of an arch for a model A style spring...
  5. Marty strode posted a really nice tech on flattening crossmembers.
    And he covered curved spring style too.
    There's a million different variables when flattening a crossmember and finding one on the shelf that suits you perfectly would be like finding the winning lottery ticket on the floor.
    There's probably a few hundred guys that can flatten yours to exactly what you want though if you don't feel comfortable doing it.
    Here's one I did. It's narrowed and although not flat, it is flatter .
    http://www.jalopyjournal.com/forum/showthread.php?t=850807&page=5
  6. revkev6
    revkev6
    from ma
    I don't know of anyone that does a bolt in, but what I ended up doing was calling up a local sheetmetal shop and having them bend up a crossmember for me. sent them a sketch with the dimensions and for cheaper than your time to flatten one would be I had a x member that I slid in place, squared up and welded in. easy peasy lemon squeazy!
    this was using a straight 40 spring btw. using a model A or a 32 spring would not work this way.
  7. cully33
    cully33
  8. tommy
    tommy
    my Deuce roadster came with a bolted in 35-39 cross member that some old time hotrodder put in it back in the 50s I'm guessing. they burned out the Deuce rivets and replaced then with bolts. I welded them up. No 'kits" available back then.
  9. GregCT.
    GregCT.
    from CT.
    I figured that there was none available, but had to ask. Thanks for responding. using a straight spring btw.
