Anybody running or have run the 'ol 327/350 horse #151 cam in a 9.0:1 350??
Discussion in 'The Hokey Ass Message Board' started by RUNNINGBEAR55, Sep 14, 2009.
  1. RUNNINGBEAR55
    RUNNINGBEAR55
    from New York
    :cool: Thinkin' of running Chevy's old L-79 #151 327/350 horse hyd. in the flat top piston 350 4 bolt I am throwin' in my 210 post 'til I gather up the stuff I need for the 292 c.i.d tri-power mill/ 3 speed on the tree to go in later. Just wonderin' if all the good things I have heard about this grind are justified. I am not lookin for the greatest cam ever designed!!! I bought this cam years back when Crane sold it un-touched from it's sixties specs. and want to try it out. How is the idle, and how high will it pull? Runnin' 4.10 gear with a low first gear 6cyl. late Saginaw 3 speed. Thanks for any info.
  2. Deuce Roadster
    Deuce Roadster
    My experience is that it was extremely TAME ... in a 350. The extra 23 inches and the lower compression made it sound almost like a stock na na na camshaft. :eek:
    Now it really talks in a 283 :D
  3. spoons
    spoons
    from ohio
    Been running one for 8 years, never had any problems, sounds good..Not a torque monster Works really good with 1.6 rockers..
  4. Shifty Shifterton
    Shifty Shifterton
    Lotta duration for a 9:1 motor but you'll be fine with those 4:10 gears unless you're running 33" tires. Good Luck
  5. R Pope
    R Pope
    I've had three of 'em. One in a 283 was pretty lopey, but revved like crazy! The other two were in 350's. The cubes did tame them quite a bit. The higher comp. one had more lope at idle, but they both had noticeable power increase over the "grocery-getter" cams they came with. I would use one again in a daily driver. Better cams out there for all-out street power, but none more driveable that I've seen.
  6. chevyshack
    chevyshack
    I ran that cam in a 305 years ago. I wasnt impressed. Seemed stock but did make great power over 30mph. But it was my first engine build and i used 350 heads with highway gears. 2.73's. Guy i sold the car to justy swapped out the rearend for a posi with 3.73's and ran low 15's at the track. It was an 82 buick regal by the way.
  7. spoons
    spoons
    from ohio
    Mine went 8:60 in the 1/8 mile, @ 88 mph with 3:00 gears
  8. LowKat
    LowKat
    Try it, you'll like it.
    beats stock
  9. Stick Shift
    Stick Shift
    from LENA IL
    Yep I got one in a 77 Caprice two door with 3:73 gears. Good daily motor. I think it pulls just as hard as the 406 did with a 280 cam did.
  10. BigChief
    BigChief
    There are much better cams out there now....but thats not a really bad one and, hey, it's already paid for. Drop it in and run it.
    -Bigchief.
