anyone a dealer of EZ or Painless wiring
Discussion in 'The Hokey Ass Message Board' started by low springs, Sep 6, 2005.
  1. low springs
    low springs
    from Long Beach
    i need some wiring and would like to get it from a Hamb'er.... thanks
  2. Lucky Strike
    Lucky Strike
    Ditto. I'm eventually going to need some too.
  3. bobx
    bobx
    from Indiana
  4. JohnJoyo
    JohnJoyo
    Alliance Vendor
    from Austin, TX
    Hey Give Mercury Charlie a call at South Austin Speed Shop (512) 693-7277, I'm sure he can help you out.
    -Junkie
  5. ironworks
    ironworks
    I'm a dealer for ron francis. There stuff is a little more but you run the wires in reverse of a painless or easy wire kit. It make a lot nice install than having 60 wires running out of the back of the fuse panel going every which way. I will never install another kit in any car that I build.
    Most kits are about 400 with headlight switch and key switch and dimmer. They supply all the switches which is nice. There was rumors of a key switch that was not the locker key style like most new key switches.
    Rodger
  6. bcarlson
    bcarlson
    Rodger, can you be more specific on this? I'm confused... thanks!
    Ben
  7. Gotgas
    Gotgas
    from DFW USA
    I've got a friend that works for Painless, let me know what you're looking for and I'll pass on some info to him.
    Danny
  8. ironworks
    ironworks
    On a painless kit you have a fuse panel with every wire you need running out of the back of the panel. Like 40 -50 wiresthat come staight out and go in every direction. There is no way I have found to make them lay out nice off the panel.
    On the francis kit the prewired circuit come form the what ever you are wiring to the fuse panel. So you can lay out the circuit and make it nice all the way to the panel where you just cut to length and screw the conectors in.
    Plus they have some ideas no ones else has yet in some of there products.
    Cooling fans relay with senders built in to the circuit board.
    Good quality stuff
  9. man-a-fre
    man-a-fre
    my ez wireing was pretty painless would recommend real happy with it.
  10. Winfab
    Winfab
  11. mexibilly
    mexibilly
    i bought mine on ebay
  12. low springs
    low springs
    from Long Beach
    thanks fellas i PMed a couple of you.
    Mexibilly.... i bought my last Painless kit of Ebay also. good price too.
  13. blue collar guy
    blue collar guy
    Hey I'm a Dealer for Ez wire our shop is in Sacramento. (916) 338-4327 Blue Collar Customs We can hook you up. Scott
  14. low springs
    low springs
    from Long Beach
    sent you a pm
