Anyone build a car titler / roller like Eastwoods ?
Discussion in 'The Hokey Ass Message Board' started by beaulieu, Mar 27, 2007.
  1. beaulieu
    beaulieu
    from So Cal
  2. dodgedartgt
    dodgedartgt
    from SW FL
  3. great segway -- In Michigan we called them rotisseries (like a pig roaster). You can build one if you get a couple of 1.5 Inch pillow block bearings & 2X4 rectangle steel stock & lots of work, AND if you know welding. They are not difficult unless you want to rotate a complete car. Frames or bodies are OK on a limited budget.
    Make sure about the mounting point strength. It's easy to twist metal.
  4. Bort62
    Bort62
    I priced out metal to build a rotisserie to spin my ranchero sans engine and suspension, it is only about 150$ worth.
    Of course, you have to be able to weld it all together, but for 1200$ you could probably even pay to get that done.
    Then you can flip the car completely on either side. (or upside down if you really want to get serious)
    Hell, you are in los angeles - I'll weld the damn thing for you for 1200$ :)
  5. Bort62
    Bort62
    I do have to say tho that this rollover crap looks even easier and would certainly take up less space. Problem is it is slightly less useful for things like painting.
  6. texoutsider
    texoutsider
    from Frisco, Tx
    An old mattress will do the same thing....with a couple of props.
  7. beaulieu
    beaulieu
    from So Cal
    thanks , that looks good, I might double up on the curved pipe but I like the concept
    Beaulieu
    any other ideas ?
    I have heard of welding something onto old steel rims,
    I am not interested in a rotticerie set-up , just like the titler / roller idea
    ummmm just figured out that I cannot spell, its tilter......Duhhhh
