Hot Rods Anyone build An Austin Seven (1930-ish) Hot Rod?
Discussion in 'The Hokey Ass Message Board' started by lake_harley, Sep 9, 2022.
  1. Stueeee
    Stueeee
    from Kent, UK
    It would probably have been deleted as it's a modern (post 1966) motor. But it's a rule that's not always consistently applied, if you read through all of this thread, you'll see some blowback because it isn't about Detroit style product.
    Good luck with your Ruby project, some really original good ideas there.
  2. Ned Ludd
    Ned Ludd
    As an ST1100 it has carburettors, so it's already well on its way to being configured in a "traditional" technological idiom. It seems a natural to me. I for one would love to see progress on your build.
    THE FRENCHTOWN FLYER likes this.
  3. goldmountain
    goldmountain
    That looks liķe a great engine to consider for my Ruby. Was it ever available on this side of the Atlantic in a longitudinal configuration? How about reverse gear?
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I've seen a motorcycle engine powered dragster that had an electric reverse - a starter motor with a pegged pinion that engaged the drive chain and backed the car up after a burnout.
  5. Ah I see, hopefully the fact that I'm trying to keep everything else old, bar the engine, will mean it doesn't get deleted, as I'd love to be able to ask questions / make a thread for it at some point.
    So for the reverse gear, I have this little box of tricks, pull the lever and it turns all your forward gears into reverse gears, 60mph in reverse anyone?
    It'll be mounted in the tunnel, in the middle of the car.
    A friend of mine is also now using a pan european engine in his morris 8 he bought, after seeing my car, but hopefully the 7 is slightly lighter than the morris 8.
    Also for the gearbox, it'll be the standard pan european gearbox, so a nice sequential gear change, only thing I haven't figured out yet, is how I want to do the clutch, it's a hydraulic clutch, so i might just mount the clutch master cylinder and lever on the gear change lever, as space on the floor in such a small car is definitely at a premium, don't know if I have the room for a clutch pedal / master
    Okie Pete, RMR&C and Ned Ludd like this.
  6. goldmountain
    goldmountain
    Glad you are still with us Dan. Looking forward to your input.
  7. banjeaux bob
    banjeaux bob
    from alaska
    13339666_619824854852752_8006869754908654588_n.jpg Not an Austin Seven or an hot rod. a Rosengart Kramerwagen...built under license from Austin. maybe they call it a Kramerwagen because there isn't much room and you have to cram it in to get it all to fit.
    Okie Pete, das858, Ned Ludd and 4 others like this.
  8. lake_harley
    lake_harley
    Sort of a dream for a potential future project it seems it would be fun to build a car on the order of this. I can envision a diminutive engine and drivetrain........ Thinking perhaps Crosley. But, Crosley engines don't seem to be exactly plentiful and in decent condition and I'd be open to suggestions of other tiny engine and driveline packages that might be suitable for a retro racer like this. Model T or Model A would seem a likely choice but I'm thinking lighter and more compact.
    Lynn
  9. Dave G in Gansevoort
    from Upstate NY
    A slightly more modern Austin engine could be a solution. The A-series used in Spridgets dates back to the 50s, and is considered the sbc of England. Thing frog eyed Sprite, or early MG Midget. Get a clapped out one and use the entire drivetrain, engine, 4 speed transmission and rear axle. They are tiny.
    Ned Ludd and lake_harley like this.
  10. Dave G in Gansevoort
    from Upstate NY
    Oh, and parts are still available. Like aluminum (aluminium for the British) heads, adapters for T5 transmissions, and practically every thing to build a quick engine, as an example, SCCA racers have gotten close to 200 hp from 1275 cc race engines. I had a 1275 still streetable pumping out around 120 hp. In a 1300 pound Mini it was quite a handful...
  11. Sandcrab
    Sandcrab
    I'm gathering parts for the 1933 Ruby that include a V8 60, T5 transmission and a narrowed 8". Possibly blown like the one blowby posted last year.
  12. Funny you guys mention this. My Buddy just picked up a 47 Crosley wagon with a 70 MG Midget drivetrain, and I just picked up a complete Crosley ch***is and drivetrain, no body. We got the MG powered Crosley started today, and I got the Crosley motor to fire yesterday. I need to rig up a fuel tank and fuel pump to start the Crosley and let it run.
  13. banjeaux bob
    banjeaux bob
    from alaska
  14. banjeaux bob
    banjeaux bob
    from alaska
  15. banjeaux bob
    banjeaux bob
    from alaska
    Adam Wragg in one of the several specials 358086065_10159838524345770_1702846596346237700_n.jpg his father built. See post #133
    Okie Pete and rod1 like this.
  16. banjeaux bob
    banjeaux bob
    from alaska
    From Martin Port from Cl***ic and Sports Car Magazine:This is what he has to say about the car:-
    For context - 1934 Austin Seven ch***is, bought last August after someone suggested on the final day of the 2022 Cl***ic that I couldn't build a special and drive it to Le Mans for the centenary. Up until I took it and drove 400-miles.Built entirely from reclaimed aluminium – old bus panels, a Land Rover bonnet etc. 1972 Reliant 700cc engine and gearbox. Seats from an Austin K2 fire engine! 359744788_6615103795222941_6224148362600221637_n.jpg 359705095_6615103631889624_5713520233992473202_n.jpg 358548546_6615103611889626_2088541672250941922_n.jpg 358554077_6615103661889621_1816388960241482189_n.jpg
    Okie Pete, James D, RMR&C and 3 others like this.
  17. banjeaux bob
    banjeaux bob
    from alaska
  18. 2manyseats
    2manyseats
    from London, UK
    This is an old tech book worth searching out.
    Stueeee and Ned Ludd like this.
  19. fourspd2quad
    fourspd2quad
    The Salamander Special was made from an Austin Seven. 964210af326c746e181c9dc9239c6a10.jpg 826cd95cdf4ed30461281777055ba29b.jpg
  20. banjeaux bob
    banjeaux bob
    from alaska
    Okie Pete, rod1 and Ned Ludd like this.
  21. banjeaux bob
    banjeaux bob
    from alaska
  22. hotrodA
    hotrodA
    Probably a good thing for me that they’re not abundant in this part of the country.
    The temptation would be just too great.
    Cool little ******s!
    Thanks for the exposure to this part of automobilia.
    Ned Ludd likes this.
  23. Dave G in Gansevoort
    from Upstate NY
  24. banjeaux bob
    banjeaux bob
    from alaska
    They aren't for folks with big "hearts" ....are they?
  25. banjeaux bob
    banjeaux bob
    from alaska
    39171379_10155629819045770_3457161859658940416_n.jpg Wragg Single Seater AW MK3 004. VSCC Mallory Park 2018
  26. Stueeee
    Stueeee
    from Kent, UK
    rod1 and banjeaux bob like this.
  27. neilswheels
    neilswheels
    from England
    A couple from the UK in the 70's/80's. Small Fry, the Blue Austin was a well known car, and Rubelion, the yellow Austin with a blown Daimler Hemi, built by Pip Biblicombe, went through various updates, ending up prostreet. Apparently now in Canada
    Okie Pete likes this.
  28. banjeaux bob
    banjeaux bob
    from alaska
    70587422_10156482575460770_210192422406193152_n.jpg Mr. Wragg at Donnington. See also posts #133 and 135. A.W. pic.
    RMR&C, Okie Pete, rod1 and 1 other person like this.
  29. banjeaux bob
    banjeaux bob
    from alaska
    379987530_6572345632801694_6972581754685632537_n.jpg 379105640_6572346472801610_2188836145767669994_n.jpg 380002576_6572353816134209_1743254953672943806_n.jpg A few SEVENS at Remparts d'Angouleme 2023 M.H. pics
    RMR&C, 34 GAZ, AccurateMike and 3 others like this.
  30. Grandadeo
    Grandadeo
    That's a mighty fine looking Bantam you've got there.
    Lee
