Anyone done a TKO swap?
Discussion in 'The Hokey Ass Message Board' started by wayfarer, Nov 12, 2003.
  1. wayfarer
    wayfarer
    We are just getting ready to update my dad's '63 bonneville convertible. It already has a '71 pontiac 400 in it. He wants to replace the TH350 with a five speed manual transmission. We were thinking of using the Tremac transmission, a stock bellhousing and an aftermarket dual pedal set up for a hydraulic clutch linkage. Has anyone done something similar with this transmission?
  2. ELpolacko
    ELpolacko
    Never done the swap your looking for but I do have a TKO sitting behind me waiting to go into my 63 F100. Seems to be a straight forward install to me, buy the parts and go nuts! Unless your making over 400 horse or so I would stick to the 3550, bit cheaper and shifts smoother. Other than that the TKO is one stout Mo Fo!
    You should be able to source a brake and clutch under dash assembly from a lesser car similar to yours. Knowing GM the Impala/Biscane stuff should be a close fit.
