Anyone else building old dodge/plymouth other mopars?
Discussion in 'The Hokey Ass Message Board' started by wayfarer, Nov 6, 2003.
  1. 50dodge
    50dodge
    from Carlton,OR
    i am in the process of doing my 1950 dodge meadowbrook..its a 4 door. i need to take more pics of it but here you go...[​IMG]
    [​IMG]any advice is welcomed!!
  2. rusty1
    rusty1
    ...that's a 33 or 34, 32's were all 3 windows.
  3. the SCROUNGER
    the SCROUNGER
    from USA
    I've always been a GM man, Pontiac-Olds 1965-up engines, but recently branched off into older and different makes to keep it interesting. Recently obtained 3 Chrysler polys, 2 Dodge polys, a Dodge hemi, and a Chrysler hemi, to sort out/see what makes them tick. They look like very well designed engines, and the metallurgy in these engines is high quality. Very few have any stripped or stubborn bolts, due to high nickel content in everything, cores and hardware, they really resist corrosion. All but one, all head/intake/exhaust manifold bolts came off without breaking/stripping, using an electric impact gun 110 v- only one engine required torch work on exhaust manifolds, because it was sitting in water in a swampy area for 40 years.
  4. desoto-S15
    desoto-S15
    I have a 51 desoto custom that has been takin every spare minute i have . I just picked up a 305/400r4 to put in it. a friend of mine is going to fab up some motor and trans mounts .. how bad with the car vibrate if it is just a solid mount with now bushings?
  5. kustomfordman
    kustomfordman
    Here's my '30 DD pickup. Still a long way to go, but getting there. The second picture is photo shopped. I still need to ge the ride height and stance squared away.
  6. James Curl
    James Curl
    I have a 37 business coupe frame with running gear and a 41 Dodge flat head that has been modified to install into it with a T-5 transmission. Will need to find some type of body for it. Want to build a solid rat rod out of it. Also have a 51 Dodge frame, running gear and motor with fluid drive to try and do something with. I have a 48 Plymouth 4 door that I need to replace the crank in and start back to driving. Drove the 48 4600 miles last summer to hot August nights in Reno Nev. and to Bonneville then through the salt water at the entrance, still getting salt residue out of the frame and lower parts of the running gear. I have fabbed brackets and adapters to adapt later model MoPar upper "A" frame and spindle with discs and an adapter and lower ball joint in original lower "A"frame. This I will install on the 51 Dodge ch***is to see if it will work before installing on the 48 Plymouth. I can get to everything on the ch***is without the body, would need to pull the 48 front clip otherwise as I do not have a lift and working on yours knees under the fender is not my idea of fun.
  7. Gotgas
    Gotgas
    from DFW USA
    Got my wagon on the road weekend before last and drove it to Austin for the Roundup. Had a ball. :D
  8. terrydrace
    terrydrace
    from iowa
    working on 51 desoto conv
  9. mknz
    mknz
    Not really building this one, but we're working on this 52 Meadowbrook to make it a daily driver (belts, radials, disc brakes)...simple stuff for now. It's got 88k original miles and somebody did a restoration on it a couple decades ago...smells old again.
    It's got a Hydroglide 3-on the tree...never heard of it, but it's like a auto/manual hybrid, plus the original flathead inline 6.
    We'll probably lower it, convert it to 12v, mess with the exhaust and all...but it's pretty much done.
  10. mknz
    mknz
    Here's my project...a 52 Dodge 1/2 ton 3-window. It's complete and then some...just in parts right now. Got an extra front end we'll probably do up into a club bbq trailer.
    And here's the cab and front end of a 48 1/2 ton 5-window sitting in my yard...still got the curved gl*** and the cracked straight to make patterns...it's available...and has some extra stuff too.
    It's sitting next to my buddy's 52 Willy's Aerolark (only one of those three that runs..sorta) and just outta frame is the 52 Cadi Fleetwood sitting under a tarp.
  11. 8thdaycr8
    8thdaycr8
    Just rolled it out of the garage the other night. Put the rear tires on last week. Front suspension/frame work will be done by the end of the month. Cab, bed and fenders will be blasted soon. The picture of the 241 Hemi is how mine will end up, but more likely with a 3x2 or 2x2. It's a small garage but at least I can move around it. What else can I expect for living in SF.
  12. cuhemida
    cuhemida
    building a 48 dodge copue pic's to com later
  13. HandBuilt
    HandBuilt
  14. rob-redm
    rob-redm
    here is mine , oh you got to like the grocery getter's ! swapping to 57 Fury caps( 59 aren't as cool !) already lowered two inches in the rear, cranked down in the front, new dual exhaust. My buddy rebuilt the carb, need to fix the exhaust leak. New brakes, and a owned by one family since new !
  15. rodbuilder
    rodbuilder
    I built a 51 DeSoto about 10 year ago wiuth a tube ch***is and a front mount blown Hemi, like a Potvin set up, but I built everything to underdrive it.
    I currently have a 55 Chrysler New Yorker Deluxe convert project, they only made about 43 of them...I want to cut it up....
  16. mayej
    mayej
    from Tok, AK
    Here's the 50 Dodge I WAS working on. The job is closing down this terminal so I gotta find something else, so all toys are on hold atm.
  17. TRuss
    TRuss
    My Dad and I have a '46 Coupe Deluxe. I don't have any digital photos though.
  18. KJSR
    KJSR
    from Utah
    I'm in the process of re-doing a 37 Plymouth P4. I have owned it for a couple of years and decided it it time for an upgrade:). I'm installing a small block, auto trans, power brakes and an updated rear end. I will end up painting it some type of old school grayish green after the ch***is is done. The body is coming off this weekend.:eek: In the end it will appear stock from the outside.
  19. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    i have a 52 plymouth biz coupe
    my parents have 3 30's mopars
    try to get picks up when i get home
  20. dodgeman33
    dodgeman33
    from Indiana
    Heres mine 33 dodge pickup and 56 dodge custom royal
  21. Al Consoli
    Al Consoli
    These all belong to my old friend "Worm". He's owned the 34 coupe since 1963.
  22. How about some more shots of the '33?
  23. Vorhese
    Vorhese
    Here's my 53 Desoto Firedome. I'm rebuilding the top end/carb and I got a visor and skirts for it I'm cleaning up. Interior is original and needs some work, maybe next summer. Also lowering it. Trying to keep it tasteful and moreless stock.
    Photoshop
  24. chattacuda
    chattacuda
    from Dayton, TN
    Building a 37 Plymouth Truck street rod. 5.7 hemi, trans, and rear end. Coil overs front and rear. Lot of work to do on body yet. Plymouth trucks are not the easiest to find sheet metal for you know!
  25. glendale
    glendale
    this is my 51 plymouth two door hardtop. chopped 4 inches, 49 desoto back gl***, 350/350 jeep cherokee rearend. and a lotta work left to do.
  26. GreggAz
    GreggAz
  27. twofosho
    twofosho
    My brother's 28 Dodge Victory Six, quietly waiting it's turn.
    Found a double dip axle and 8 1/4 rear end for it already. We had planned to find a B or RB motor, but with gas prices heading for four bucks a gallon plus, it's more likely the 318/904 I pulled out of my Coronet when it got a 383 is more likely.
  28. How did you achieve that fender hugging stance? What is your ch***is setup? Is it still parellel leaf front and rear? I ask cause I have a 24 DB touring that I want that hanging on the rubber stance for. My idea is to convert to model a style front supension, but I would like to know what you did. Awesome looking car great job!!
  29. FinnishFireball
    FinnishFireball
