1952-59 Ford Anyone else have issues with DC ignition switch?
Discussion in 'Off Topic Hot Rods & Customs' started by evintho, Nov 18, 2022.
  1. evintho
    evintho
    I can barely get it to turn to start or to accessory.
    https://www.dennis-carpenter.com/trucks/electrical/ignition/b5a-11572-a-ignition-switch-housing-only
    The key is already bending and starting to break. I pulled the tumbler cylinder out and it turns fine. The problem is the tolerances inside the switch housing are way too tight. Once I pulled the cylinder out I turned the switch back and forth with a flat blade screwdriver about a thousand times (literally) and that didn't loosen it up at all! I even took it to a locksmith and he just confirmed my su****ions. Too tight. I don't even know if I can return it as I bought it a year ago. Even if I could, where could I get a quality switch that wasn't made in the same chinese factory? Any help is greatly appreciated!
  2. 51504bat
    51504bat
    Not with an ignition switch but the DC headlight switch I got from Shoe Box Central was defective right out of the box. Shoe Box Central sent me another no problem. The new one wasn't much better but at least it works. JMO
  3. Alan Freeman
    Alan Freeman
    The above is why I always try to use good original Henry parts preferably NOS. I have found that even 70 year old good used Henry parts are far better than the repro. stuff which I try to avoid.
    JeffB2 and bobss396 like this.
  4. 56longroof
    56longroof
    Good old made in China strikes again.
    JeffB2 likes this.
  5. 56longroof
    56longroof
  6. bobss396
    bobss396
    I chucked my OG ignition switch, I had little confidence in a switch that old. Maybe I should have saved it. I got a "quality" one from Napa. I have to use Lock Ease on the key, it doesn't always want to come out when I shut the car off. I have had problems with practically anything I bought for the car from Napa.
    JeffB2 likes this.
  7. Texas57
    Texas57
    Not an ignition switch, but the Dennis Carpenter door jamb switches for the dome light fell apart just trying to install.
    Fortunately, Ron Francis had better quality ones. I do not use an oem style ignition switch, so can't recommend anything. (late model steering wheel w/ key switch and separate ignition switch)
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    bobss396 likes this.
  9. evintho
    evintho
    Update: I was able to salvage my factory ignition switch. Problem was the key wouldn't turn so I removed the cylinder and replaced it with the DC cylinder and keys and it seems to work well. The key turns smoothly to acc, off, on and start and there's power to the posts that should have power so, that problem is solved. Now I have to deal with some other electrical issues. Isn't life grand!
    JeffB2, bobss396 and the-stig like this.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    What other issues ?
  11. evintho
    evintho
    Electronic fuel injection and computer control. Thought I had it figured out......apparently not!
  12. Texas57
    Texas57
    refresh my memory if you would......what engine/year/wiring, etc.
  13. evintho
    evintho
    '93 Mustang 5.0 with factory ECU and wiring harness.
  14. Texas57
    Texas57
    "factory wiring" is way over my head.
    JFYI, Ron Francs' wiring kit for the 5.0 is about 1/2 the complexity and cost of their 4.6 harness that I used. It turns it into a pleasurable job.
  15. jimmy six
    jimmy six
    I bought “Standard” brand replacements from a local parts store for both 10 years ago. They are possibly still available. As I remember I had to file something on the ignition switch.
