1952-59 Ford Anyone else have this problem with rear shackles?
Discussion in 'Off Topic Hot Rods & Customs' started by evintho, Aug 18, 2020.
  1. evintho
    evintho
    The rear leaf spring eye is supposed to ride on top of the shackle mount. Whenever I place a jack under the 3rd member, jack the car up, place stands under the frame then let it back down.....the shackles rotate and wind up in this position. The only way to get them back into the proper position is to jack the car up at the 3rd member, place stands under the rear portion of the springs then let it back down. What am I missing here?
  2. flyboy89
    flyboy89
    from So. Cal.
    Pretty common when you jack up the body and let the axle hang down. Kind of a pain to get them to flip back over to a normal stance but can be done. I've had to flip these back over a couple of times. I've put jack stands under the axle to support it then slowly lower the body and using a pry bar to flip them back. Have to kind of work it down into position. This happens every time I want to remove a rear tire as I have 1" lowering blocks. Have to dis-connect the shocks also. A pain in the ****.
  3. 56longroof
    56longroof
    I have 2" blocks in mine and never have had any trouble. Are your bushings in good shape? Maybe they are wore enough to allow extra movement.
  4. 56FORD390
    56FORD390
    I use a crow bar to pop them back as the car is let down off the jack. Pop them after the tires just touch the ground with no real pressure on them.
    Texas57 and DIYGUY like this.
  5. evintho
    evintho
    OK, so it's not just me! Bushings are brand new. I'll try the pry bar trick next time I jack her up.
    Thanks everyone!
  6. Yutan Flash
    Yutan Flash
    from Gretna, NE
    Gee, back in the late 60s-70s we went out of our way to flip the shackles to "jack up the rear" and get a nose-down rake. Of course a good set of Gabriel Hi-Jackers helped. ..
  7. Texas57
    Texas57
    My '57 is really close to doing it also. With mine it's because I use shocks that let the differential drop an additional 2" for tire changes, which fortunately hasn't happened yet, lol. Guess I'm not burning enough rubber, but with 39k miles on them now, they don't look half worn.
  8. 54vicky
    54vicky
    as flyboy said very common same thing happens with tandem axle trailers.also as flash said that was a common and cheap way to add rake:Dworn bushings make it easier to flip back
  9. BruceMc
    BruceMc
    from Alaska
    Looking at the angle of the shackles, are the springs maybe a little shorter than stock?
  10. flyboy89
    flyboy89
    from So. Cal.
    Springs are ok. It just looks like the springs are too short.
  11. evintho
    evintho
    Original factory springs.
  12. Fairlane 62
    Fairlane 62
    Yeah I run them flipped on my 54 to add clearance for the slicks, and flipped on the 58 because the springs are flat and need replaced.
  13. jimmy six
    jimmy six
    You see a lot of them for sale like this... Most of them say "restored" They do it to get them level. 60 year old leafs sag and started sagging early. Stock old rears and AeroStar fronts give a nice Taxifornia rake.
  14. !!!RIOT!!!
    !!!RIOT!!!
    from Austin, TX
    I had to drop and re-install the rear end 6 or 7 times when I was doing the axle replacement recently and I got pretty quick at dealing with this. I would just put the edge of the jack under the shackle and jack it while pushing to the front until it was mostly level and stick a board under it to hold it. Switch to the other side and do the same, then jack up the 3rd member. The boards will keep the shackles from flipping back under and will just fall out once the shackles starting heading up in the right direction.
    JeffB2 likes this.
  15. Black Wagoon
    Black Wagoon
    I just installed 3" Lowering Blocks, only to find the rear end HIGHER than when I started. WTF?
    I noticed shackles were in the lower position, but never heard or felt the shackle rotate.
    New Bushings and Shackles on order. Hopefully, that will take care of the slop in the spring mounts.
  16. 54vicky
    54vicky
    good luck with removing the bushings a torch will be your friend.plug your nose also
    Black Wagoon likes this.
