Hot Rods Anyone Else Running a Mallory Dual-Point with (2) 94's?
Discussion in 'The Hokey Ass Message Board' started by mdogg1950, May 20, 2025.
  1. mdogg1950
    mdogg1950
    ...if so, we need to talk. First of all, I'm relatively new to the flathead scene and I'm gradually learning about these marvelous mills (I always wanted one). And I'm starting to ponder the voluminous info you great folks have posted on the Ford (Holly) 94. So here we go:
    My '50 8CM Merc has (2) 94's, a mild cam and a dual point Mallory. The diz has no vacuum advance. I set each set of points at .020. The plugs are Autolite 216 (gapped at.028, too new to evaluate).
    Problem: engine runs ok at idle but has no power. Plugs (Champ H10C) turn black in a few miles. I've read it's advised to lower the float level slightly. OK, will do. I've read jets should be .051. Will check. Also, will time the engine.
    Any other thoughts on getting this combo to run right? I didn't build the engine, so I think I'm trying to iron out someone else's "tuning".
    Thanks as always,
    Matt
  2. tubman
    tubman
    What are you running for power valves?
    warbird1 likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    O2 gauge then Remove ,
    I spent several hours Jets & Pvs
    Added O2 dialed it in like less then 1hr
    Few test drive around block ,
    My Flatly timing it liked around
    13 deg BTD @ idle
  4. mdogg1950
    mdogg1950
    The FRONT carb is now disassembled on my bench. Jets are 048. I do NOT see a number on the power valve. Please advise how to identify said PV. Thanks.
  5. mdogg1950
    mdogg1950
    UPDATE: Even with a magnifying glass I'm having trouble, but it looks like there are three numbers on the circumference of the PV spaced about 90 degrees apart: 7 5 7 Unsure how to translate these numbers; I'm in uncharted waters.
    gimpyshotrods likes this.
  6. wheeltramp brian
    wheeltramp brian
    That's a 7.5 I believe
    clem likes this.
  7. 19Eddy30
    19Eddy30
    from VA
    Test with Vac pump ,
  8. 31 Coupe
    31 Coupe
  9. gimpyshotrods
    gimpyshotrods
  10. mdogg1950
    mdogg1950
    Installed 3.5's. Filled bowls with fuel on my bench to make sure of no leaks. Considerable improvement. Amazing how good it runs without raw gas running down its throat! (May have to change diluted oil?)
    Thanks again to everyone.
    Matt (caretaker of '50 Merc named "Rebel50")
    Toms Dogs likes this.
  11. clem
    clem
    yes, before you drive it.
    Did mine yesterday, same problems, leaking ‘94’s…………
