Technical Anyone ever remove top ribs in Model A Coupe top?
Discussion in 'Traditional Hot Rods' started by bartmcneill, Jan 2, 2015.
  1. bartmcneill
    bartmcneill
    from Ada, OK
    I need to weld my coupe top onto my sport coupe body. The top is in pieces. Has anyone ever left out the ribs on each side of the rear window, welded it solid and smoothed it out to look like more like a 32 top. I plan to fill the top with metal and have never really liked how the ribs in the back have no place to really go, they just stop at the insert area. Pictures of examples would be appreciated.
  2. RMR&C
    RMR&C
    from NW Montana
    Yes.........
  3. clem
    clem
    that coupe in post 2 looks good.
    1927graham likes this.
  4. The37Kid
    The37Kid
    I did on a '29 Tudor years ago, it looked nice. Bob
  5. snopeks garage
    snopeks garage
    from macomb MI
    I did my tudor also. Alot of people do it.
  6. dan31
    dan31
    I think the ribs add character, but they can certainly look good without them as well.
  7. scrap metal 48
    scrap metal 48
    I agree^^^...
    need louvers ? likes this.
  8. 'll
  9. HOTRODPRIMER
    HOTRODPRIMER
    Yes sir,on 3 different Model A sedans. HRP
  10. Looks better with out the ribs IMO and you don't have to worry about water and rust building up under it :rolleyes:
  11. akoutlaw
    akoutlaw
    Do you have any pictures of how the roof was finished where the visor is attached on this car? I'm doing a 30 pickup, and want to replace the top with a steel section. Thank you. Bill
  12. The37Kid
    The37Kid
    [​IMG] That is the back of my '29 Steelback Fordor, the largest one piece of bodywork that Ford produced up till that time, smooth no ribs. Factory welded three pieces to make the one, with the seams finished in lead.
  13. bartmcneill
    bartmcneill
    from Ada, OK
    That is what I am looking for. I will not put mine in and definitely a top chop. How much did you chop? Yours looks great.
  14. RMR&C
    RMR&C
    from NW Montana
    Bart, it's not my car....I just did the body and paint on it. Has a 4" chop and a 70's Jeep Wagon roof insert.
    This body was really rough.....I ended up removing the ribs and welding the seams solid. Worked pretty good.
  15. mdcolby
    mdcolby
    Couple more pics of coupe from post 2! Great work by RMR&C!
  16. akoutlaw
    akoutlaw
    Thanks for these pics of the coupe. The visor shot is what I was looking for. Bill
  17. verno30
    verno30
    I've done it to all my coupes and sedans.
  18. ct1932ford
    ct1932ford
    You asked! I think without the ribs the car looks more like fiberglass. I will admit that if you are filling the roof they will not work.
  19. Corn Fed
    Corn Fed
    Did it to a coupe and a sedan. Don't just grind off the rib and weld up the gap. Cut the whole rib out and weld in a flat strip. This will allow you to be able to smooth the area out with a hammer & dollie and removes that whole multi flange area where rust can develop or cause a stress crack.
  20. K.L
    K.L
    Never done it but I'd say it looks good both ways.
