Anyone Ever See A Rear Axle Do This?
Discussion in 'Off Topic Hot Rods & Customs' started by greasemonkey54, Sep 29, 2025.
  1. At work we had an F450 towed in because the rear wheels locked up. We found the pinion nut backed off and shoved the pinion through the bottom of the case. First time I've ever seen that happen. 20250925_083327.jpg 20250925_083318.jpg 20250925_083215.jpg
    Deuces, Johnny Gee, bobss396 and 6 others like this.
  2. squirrel
    I"ve seen the scuff marks on the carrier from the pinion being loose, but never seen one poke out the bottom!
  3. chevy57dude
    chevy57dude
    That's impressive!
  4. Dick Stevens
    Dick Stevens
    That's a person that would drive it as long as it would still move! :eek:o_O
    Deuces, porkshop, Gasser 57 and 3 others like this.
  5. slowmotion
    slowmotion
    Damn, wonder if the housings are now made of Chinesium? :eek:
    Deuces and porkshop like this.
  6. rockable
    rockable
    A big truck lost his pinion as I was following on the Interstate years ago. The whole pinion dropped out of the rear! I couldn't avoid it. It hit the transaxle case of my Saab Aero and blew oil all over the turbo and exhaust. The smoke looked like an old Nascar blown engine.
    Deuces, Ned Ludd, porkshop and 2 others like this.
  7. gene-koning
    gene-koning
    "Yea, she's making a whole lot a noise, but I think we can make it home, lets run her straight down the highway, its a few miles shorter...." A 1/2 mile down the road, a big BOOM, and locked up rear tires. Man what a ride that would have been!
    rockable and SS327 like this.
  8. Mike Lawless
    Mike Lawless
    As a lifelong drag racer, I've seen a lot of carnage, even doing a fair bit of my own.
    I've had the differential spider gears exit clear out of the rear cover, I've sheared the pinion gear head clean off,
    I've broken the transaxle case clean in two on my VW drag car, spitting the contents out onto the starting line.
    I've had more axle, and ring & pinion failures than I care to think about.
    But I don't think I've EVER seen anything like that!
    Deuces, Ned Ludd, slowmotion and 4 others like this.
  9. That's basically what happened
    Deuces likes this.
  10. SS327
    SS327
    Yup, seen that before. But the pinion exited the back.
  11. deathrowdave
    deathrowdave
    from NKy
    Just started to make noise
    Deuces likes this.
  12. gene-koning
    gene-koning
    It almost looks like the pinion nut backed off until it ran out of threads, broke off or stripped out the threads holding the nut on.
    A few of the OEM rear ends under some Dodge pickups had the problem with the pinion nut loosening up. It would start out sounding like a U joint was starting to go bad, but would often just make the noise when you went from forward to reverse (or the other way). On the Dodge truck rear ends, it didn't have to go far enough for the pinion nut to actually come off to cause the problem. Just a couple revolutions of the pinion nut loosening would be enough to allow the pinion to slide back in the case and bind between the ring gear and the case. The operation of the ring and pinion would tend to pull the pinion gear back into the ring gear until the pinion gear would wedge between the case and the ring gear. The binding would cause the rear end to lock up both rear tires. If the truck was rolling at any speed, the case was often the weakest point, not that it mattered much at that point.
    In the pictures its plain to see the pinion has fallen completely back into the case, to do that, the U joint yoke had to come off the pinion gear as well. This total pinion retaining nut failure event would have also allowed the driveshaft to become free of the rear axle and could have caused additional damage. I can not see if the threads on the pinion broke off, or if the threads holding the nut stripped out, or if the nut simply unscrewed.
  13. Sharpone
    Sharpone
    It ran and drove when I parked it.
    Dan
    Deuces and Mike Lawless like this.
  14. The pinion nut did back off. No damage to the threads.
  15. TA DAD
    TA DAD
    from NC
    I noticed it had a vibration but I didn't think much about it.
  16. In drag racing, most of what I saw was so tore up you weren't sure what happened. I have never seen any gear out the bottom. :)
  17. RodStRace
    RodStRace
    I'd consider the engineering and metallurgy of the pinion to be superior!
    Seeing @squirrel reply to a freed up pinion after his recent escapades is humorous!:D
    greasemonkey54 likes this.
  18. [QUOTE="RodStRace, post:
    Seeing @squirrel reply to a freed up pinion after his recent escapades is humorous!:D[/QUOTE]
    I didn't think of that. His would not. Ove and mine fell out while driving
  19. Don West
    Don West
    couple new gears and a little creative use of J B weld and you'll be back on the road no problem.
  20. gene-koning
    gene-koning
    The fun (?) thing about killing a rear end like this is, it doesn't require much HP to do the job. I bought an early 90s V6 Dodge Dakota really cheap because the rear end was "locked up" and leaking gear lube through the crack in the bottom of the case. The pinion nut backed way off, allowing the pinion to drop back and bind against the case. I think the only 2 things that kept the pinion from coming through the case was the yoke was still attached, and the guy probably was not going very fast.
    I removed the drive shaft, put a socket and ratchet onto the pinion nut so I could pull the pinion back up into place and tighten the nut, then I reinstalled the drive shaft and was ready to drive the truck home. The guy was seriously mad when he watched my do my thing and was ready to drive the truck away! He told me that if he knew that was all he had to do, he would have patched up the case with JB weld and drove it another year. I did drive it around the house for a month or so, until I was ready to strip the truck out.
    greasemonkey54 and Sharpone like this.
