Anyone ever use a vacuum pump?
Discussion in 'The Hokey Ass Message Board' started by Francisco Plumbero, Jul 8, 2010.
  1. big bad john
    big bad john
    ......Why would you need it? most motors have enough vac***
  2. hammerstien
    hammerstien
    Read the thread before you open your pie hole. His ENGINE doesn't have enough. Motors are electric.
  3. 29AV8
    29AV8
    at work we have older chevrolet dump trucks trucks with vacuum brakes 366 or 427 engines they all have a vacuum tank under the cab they have been using them on applications like this for years. you should be fine with a tank... my 2 cents.
  4. RDR
    RDR
    this blown model A has 4 wheel disc brakes with a Delco electric vacuum pump (pt # 5048967 )...goes like HELL:eek: and stops like NOW:D !!
  5. Francisco Plumbero
    Francisco Plumbero
    from il.
    I ended up using a storage can with a check valve, works well.
  6. RDR
    RDR
    FP...thanks for the comeback...glad all worked out for you !
  7. themoose
    themoose
    The word "motor" refers to anything that provides motive force to an object. You'll notice that rockets are commonly referred to (by Ph.D. rocket scientists) as MOTORS.
    An engine is something that takes one for of energy and converts it into another, or something that produces some sort of work or energy from a given input.
    Car engines are both engines and motors. It converts chemical energy into mechanical energy, making it an engine, and it also moves the car, making it a motor.
    Electrical motors could even be considered engines, since they take electrical energy and convert it into mechanical energy.
    Even a generator or alternator is an engine; it is still producing work or energy from a mechanical input.
    Consider motor oil,motor mount.
