Technical Anyone got a removeable soft top for A sedan?
Discussion in 'The Hokey Ass Message Board' started by Fabber McGee, Jun 13, 2019.
  1. Fabber McGee
    Fabber McGee
    I did a quick search and didn't come up with what I'm looking for. I need to replace the top on my 29 Tudor. I've been thinking that it would be good to have it easily removable like a tonneau cover and run it open on nice days or snap it on when a shower comes along, but I want it to be rain tight and I haven't figured out how to seal up the front.
    Has anyone got pictures or ideas on how to go about this?
  2. rudestude
    rudestude
  3. rudestude
    rudestude
    Look up Legacy Products they have a slide/fold ing canvas sun roof kit for Model A sedans kit price $795.00 15604242401174757294102703167564.jpeg 15604243158877958546441301984063.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    Hnstray likes this.
  4. rudestude
    rudestude
    or sunroofsource.com and Legacy Products are apparently one of the same.
  5. Getting it rain tight is probably the hard part
    Stogy likes this.
  6. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Rain tight may have to be filled with steel....
  7. Tim
    Tim
    from KCMO
  8. Fabber McGee
    Fabber McGee
    Thanks guys, I'm not crazy about all those pleats of canvas at the back when it's open. I'd rather have something I can snap on and off, that I can roll up and tuck behind the seat or some place.
    Prefer not to buy, I'm a build it myself kind of guy. Just looking for ideas.
    Probably wouldn't have to be completely dry inside while driving in a little rain, but I think most female p***engers would rather shower in the privacy of their bathroom. Need to be able to park it and come back to a dry interior.
  9. Hnstray
    Hnstray
    from Quincy, IL
    You have a lot of “female p***engers”...eh, Fabber?
    ‘re ...”coming back to a dry interior when parked”......a car cover will do the trick.
    Anything that just “snaps on” has a snowball’s chance in Hell of keeping out water while driving.....
    I do like your optimism though...;)
    Blue One likes this.
  10. I made a removable top for my "A" sedan, vinyl with snaps. I looked at some cars that had a snap-in roof panel before I built mine and it looked like the problem was that the snaps on the front edge would come undone at speed. What I did was to sew in a 1/16" thick aluminum strip at the front edge and used a post type snap. Not really a snap it is a post with a ****on on the top and a tang that sticks out at the side. You push the top ****on and the side tang will retract. These are Ford open car side curtain retainers, I got mine from Snyders but I would think most restoration vendors would have them. after about a year or two the rear edge started to stretch out around the snaps. You know how vinyl stretches. So I cut the s***ches out and slid in another aluminum strip (you can get this at Home Depot) now it works fine, not water tight but almost as good as the windshield so it's ok. The one thing I would say if you were going to do this, is do not use vinyl, try some boat top stuff, something like sunbrella I think it is called. And the aluminum strips do not prevent you from rolling it up. I'll check for some photos and post if I find them.
    Stogy, Fabber McGee and Hnstray like this.
    Not the best but you get the idea, and it is very much worth the effort to do this, so nice to be able to remove the top in the summer.
  12. Cliff Ramsdell
    Cliff Ramsdell
    I made a snap on canvas top for my Tudor. It’s not very weather tight but it’s a great sun shade on those hot summer days.
    I bought a roll of vinyl to make a more weather “resistant” but I’m sure it’s not going to be weather tight, I’m sure that will require a fixed top of sorts and that’s not what I’m after.
    Cliff Ramsdell
    37299177-7A96-453F-883B-CFD74B41DCE8.jpeg 0DDBFF96-DCFB-4ECE-9B76-86D44630FE25.jpeg 9D243372-CF77-4443-92AB-87565FA8FF34.jpeg F2492802-CE75-4F03-8F88-1898354AE16A.jpeg
    Stogy likes this.
  13. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    The pleats may not be the favored look, but I have a friend with a late model caddy lowrider that is running one of those soft folding top sunroof things. Not only is his water tight (98% dry) but its not terribly loud going down the road either. A lot of the simple snap on style will be wet, and loud!
    Stogy likes this.
  14. Cliff Ramsdell
    Cliff Ramsdell
    Stogy likes this.
  15. Rocks Rod & Custom
    Rocks Rod & Custom
    from Raytown MO
    I fabbed an aluminum frame insert for this a sedan. It has pins at the rear and bolts up in the front. It was quite a bit of work to Fab the channel that the insert fits into to get a nice tight and flush fit. IMG_20180404_184918_019.jpg IMG_20161207_171127.jpg IMG_20170201_104003.jpg
    Sent from my Pixel using The H.A.M.B. mobile app
  16. Tim
    Tim
    from KCMO
    Looks great though, worth the effort!
  17. alchemy
    alchemy
    The insert in my 32 sedan is nailed, caulked, and sealed like Henry Ford intended and it still leaks. I think it's rather humorous that you think a removable insert could be water tight.
    What did the vintage VWs use on their sliding tops?
    teach'm likes this.
  18. Fabber McGee
    Fabber McGee
    46 International, that's the stuff I was looking for. Helpful ideas and photos, not just "It won't work, forget about it." So, thank you.
    Hnstray, as a matter of fact, most summers I do end up having had several different female p***engers. I haven't taken a poll, but I'm guessing that most of them would prefer to be mostly dry when they get out. Don't figure I'll carry along a car cover in case it rains a bit while I'm in Home Depot.
    Anyone else have something helpful?
  19. Check out caravan awnings, they have an aluminium channel on the caravan and a piping sewn into the awning which slides into the channel. If you mount the channel at the front and snap clips or even Velcro on the sides and rear. Use convertible top material, it doesn’t stretch much, and will be more stabile.
  20. rudestude
    rudestude
    This is used on RV awnings. The leading edge has a plastic insert sewn into the canvas and then it slides into the round channel strip that is mounted on the RV body. 20190617_210134.jpeg 20190617_210117.jpeg 20190617_210111.jpeg
    dana barlow and Fabber McGee like this.
  21. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Most have more leaks around doors than roofs anyways.. haha..
    Mine was in many downpours... Just convertible top material.... Front and rear were Velcro (industrial) sides had snaps... The material was doubled up and sewn on the edges. the overlap of the top was 2" beyond where the wood was... The middle roof bow over the b pillar had another thing of Velcro there to hold it down for half way back cruising... worked great....For what I had in the top I went a lot of miles vs what that sliding top costs... And mine never leaked.... driving, sitting, whatever... not a drip of water from the top area, now the doors that's a different story... they leaked like model A's do... IMG_0656[1].JPG IMG_0657[1].JPG
  22. Automotive Stud
    Automotive Stud
    My buddy had a local trim shop make this up for his A. He put snaps in the body, and along the front edge it had a flap that also snapped to the inside of the header to keep rain and wind out.
    Fabber McGee likes this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    My sedan is still sporting the original top, material and all, I keep it supple by keeping it clean & using a silicon based top dressing, it's amazing that the top is 87 years old and still looks pretty good with no evidence of ever leaking even though I have been caught in some torrential rains.
    I will point out that the car does stay inside when I'm at home and the car was inside many years before I purchased it. HRP
  24. Fabber McGee
    Fabber McGee
    Thanks Guys!
    This is the stuff I was asking for. I had been considering awning rail caulked and riveted to the visor, but wanted to hear some first hand stories. The velcro sounds good too, but I had figured it would be pretty leaky on the front edge. Good to hear that it isn't. Velcro on a couple of the bows is a good idea that hadn't occurred to me. Both for running half open and for taking out some of the slap.
    I figured to run the material down over the curves on the lower part of the roof to where the factory top ended like Stud's buddy did to help seal it up. Black top on a black car with black fasteners, shouldn't be noticeable at all.
    The car has lived the past 60 years in my dad's old woodshed up the hill and still spends winters there and summers in the garage at my house. He replaced the top in the early 50's when he got the car, but it's coming apart over the windshield now and has black duct tape holding it together.
    By rain tight, I wasn't really asking for rain proof, haha, a few drops inside just adds to the fun of an old jalopy. Just hoping to not be as wet inside as outside. The car is still just a used car Model A from the 50's, pretty much exactly the way my dad was using it as a daily driver. I've added turn signals, modern water pump seals and a 6 volt alternator. It will remain a fun old jalopy the rest of my life and never get the restoration treatment. When the Model A club from Anchorage comes to town with a dozen of their fancy shiny cars and gets together with the local cars, my old original 50's used car with 60 years of woodshed dust on the outside gets more attention than any of the others, haha.
    Hey, it's got a 90th birthday coming up this month. I need to go check the build date. Might have to throw a party for it.
