Anyone have a manual on a Dodge
Discussion in 'The Hokey Ass Message Board' started by Koob, Jan 22, 2013.
  1. Koob
    Koob
    from Bryan, TX
    manual steering box for 1956 Coronet? I want to open mine up and see where all the slack is coming from.
  2. saltflats
    saltflats
    from Missouri
    Did you try to adjust it ?
  3. Koob
    Koob
    from Bryan, TX
    I have adjusted it all the way and still no help.
  4. saltflats
    saltflats
    from Missouri
    Did you run the screw in or out ?
  5. Gotgas
    Gotgas
    from DFW USA
  6. Koob
    Koob
    from Bryan, TX
    Salt, I ran the screw all the way in until it stopped and still no help.
  7. saltflats
    saltflats
    from Missouri
    Usealy you would only give it about 1/2 to 1 1/2 turns if you go more than that it will get tight when you turn it all the way to stop the wear spot is in the straight position where you drive the most if it takes more than that it is probably worn out and you would have to fined parts for it. Maybe better to find good used one not sure what is avalable in part for it.
  8. 73RR
    73RR
  9. Koob, the 55-56 Dodge and Plymouth use ths same box. I have a 58 Dodge manual, not sure if it would be of any help. Let me know and I'll upload some images.
  10. disorderlysaint
    disorderlysaint
    Ive got a 56 dodge shop manual if you need i can email you or text you some page shots of what you need. Pm me if needed.
