Technical Anyone have a source for carb linkage heims?
Discussion in 'The Hokey Ass Message Board' started by alchemy, Jul 19, 2024.
  1. alchemy
    alchemy
    I am designing a multi carb linkage in my head, and might want to use some double-sided heims. Does anyone have a source for these?
  2. Automotive Stud
    Automotive Stud
    Noble Speed sells them in a kit to make linkage, not sure if he would sell them separate.
    chlsnk and hrm2k like this.
  3. Oneball
    Oneball
  4. squirrel
  5. Rocket Scientist Chris
    Two thumbs up for McMaster-Carr! Fast delivery, too! :)
  6. metlmunchr
    metlmunchr
    https://midwestcontrol.com/shop/
    I've bought from them in the past. Best prices I found and good quality. Can take a while on their site because they've got about a bazillion different parts.
    Kelly Burns likes this.
  7. pirate
    pirate
    from Alabama
  8. sidewayzz69
    sidewayzz69
    I got mine from McMaster as well.
  9. jimmy six
    jimmy six
    Some of mine are McMaster, some are ACE hardware but the best ones along with pillow blocks and bell cranks come from Kinsler Fuel Injection catalog or online.
    winduptoy and gimpyshotrods like this.
  10. 1971BB427
    1971BB427
    from Oregon
    I've had no problem at all finding 10-32 heim ends. The local Ace Hardware store has them in their bins, but not cheap. I found them by several sellers on Ebay, and got a bunch of them for $2.50 each to do my dual quads on my tunnel ram.
  11. Mr48chev
    They don't or didn't used to get whiny about small orders either. Some supply houses have minimum orders = stock orders but they are happy to sell you just what you need/want. You need your best decoder ring on when figuring out their online catalog times though.
  12. alchemy
    alchemy
    The double ended from Midwest Control are exactly what I was looking for. Thanks
    winduptoy, vtx1800 and Oneball like this.
  13. alchemy
    alchemy
    So do you all think the 10-32 is hefty enough, or should I bump up to 1/4”? This is for a staggered four Strombergs, but all in one, not progressive.
    Adriatic Machine likes this.
  14. swade41
    swade41
    from Buffalo,NY
    10-32 should be fine since you're pulling on the threaded end, not bending it like a banana. I did use 1/4 on my t-bucket because that's the size I needed for the heims I had.
    Everything else on my other cars is 10-32
    winduptoy, alanp561, rod1 and 2 others like this.
  15. swade41
    swade41
    from Buffalo,NY
    I'd like to throw a quick question out since we're on this topic.
    Does anyone know who sells a 12 inch long aluminum hex shaft for the linkage, I'm not having any luck finding that length for this carb.
    Screenshot_20240719_120503_Gallery.jpg Screenshot_20240719_120428_Gallery.jpg
  16. squirrel
    McMaster sells hex stock, and you can cut it to length, stick it in your lathe, and drill and tap the ends. They sell the left handed taps, also. Be sure to turn that little line around the end with the LH thread so you'll remember later.
    what, you don't have a lathe? Get with it!
    winduptoy, LWEL9226, vtx1800 and 2 others like this.
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I used these recently:
  18. swade41
    swade41
    from Buffalo,NY
    I was chuckling reading the cutting it and threading it on a lathe, even more so at your last line, because you know I don't have that fancy equipment LOL
    winduptoy likes this.
  19. pirate
    pirate
    from Alabama
    swade41 likes this.
  20. nochop
    nochop
    from norcal
    squirrel likes this.
  21. alchemy
    alchemy
    This is what the linkage will link. Fresh from Uncle Max. Set to live atop a 409.
    winduptoy, alanp561, Chucky and 10 others like this.
  22. BHRS
    BHRS
    from Texas
    Very nice! What's the coating/color on them?
  23. Flatrod17
    Flatrod17
    Alky Digger sells various length 10/32 threaded hex shafts. They are aluminum.
  24. larry k
    larry k
    I use (Rod End Supply ) they have the ends you need !!!
  25. Adriatic Machine
    Adriatic Machine
    Another thumbs up for McMaster but I’ll take a look at the other links provided here just for good measure
  26. hrm2k
    hrm2k
    I haven’t beaten this setup yet but am amazing at how solid it all feels. I think it was built by Moriarity at least it was on the manifold when I got it. If it would help, I would be happy to get some close ups for you. This is on my 283
  27. Adriatic Machine
    Adriatic Machine
    @swade41 if I may ask, what brand are those splined shafts and black linkage arms? I found a stash of them at the swap meet and they work great but I’d like to order another length of that shaft to correct an issue.
    alanp561 likes this.
  28. wvenfield
    wvenfield
    I went to a local place all the dirt track guys go for their parts. Heim joints galore. All sizes.
    winduptoy and alanp561 like this.
  29. 19Eddy30
    19Eddy30
    from VA
    Kinsler Fuel Injection ,
    More then any other company I seen or know of ,
    From typical simple to complex,
    & Aviation / Aerospace
  30. swade41
    swade41
    from Buffalo,NY
    That's an Enderle setup, Good Vibrations Racing sells their kits, shafts are listed after the linkage kits
    https://www.goodvibesracing.com/Enderle_Linkage_Kits.html
    Edit : they even sell that damn hexagon shaft I was looking for, all the stuff I order from them and I never scrolled down that far LOL
    winduptoy, Adriatic Machine and rod1 like this.
