Technical Anyone have a source for carb linkage heims?
Discussion in 'The Hokey Ass Message Board' started by alchemy, Jul 19, 2024.
  1. bobss396
    bobss396
    I have either Moroso or Mr. Gasket 1/4-28 heim ends on my Ford. I used round aluminum rod from Ace for the shaft, I milled flats on each end so I can get a wrench on it.
    Adriatic Machine likes this.
  2. Adriatic Machine
    Adriatic Machine
    Thanks! That’s exactly what I was looking for. Glad you found the hex shafts too.
    swade41 and alanp561 like this.
  3. hrm2k
    hrm2k
    It would seem that you have found the pieces you were looking for. While I was at my garage this morning, I tried to get a couple of detail shots of the mounts on my manifold. As I was looking at it, I became more impressed with the engineering…..so just in case , here you go
  4. 1971BB427
    1971BB427
    from Oregon
    I used 10-32 for all my dual carb installations, and even used 3/16" aluminum rod I cut and threaded to make it all up. With the stress of pulling on linkage being extremely low it wont break. Just be sure to use 10-32 jam nuts at the heim ends to help keep it locked in place and strengthen the whole setup.
    The heim ends also have the advantage of reducing the pedal pressure since they move more freely than other rod attachments. I use 3/8" heim ends on any clutch linkage I build also, and they make slight angles work better, and the felt pedal pressure lighter.
    bobss396, winduptoy and gimpyshotrods like this.
  5. Adriatic Machine likes this.
  6. Adriatic Machine
    Adriatic Machine
    I got one like that from McMaster, can’t wait to swap it into the mix
    bobss396 and gimpyshotrods like this.
  7. gimpyshotrods
    gimpyshotrods
    They don't, still.
    Their warehouses are largely robot-picked.
    The robots don't care.
    rod1, winduptoy and Special Ed like this.
