Anyone have experience with the Vintage Speed 2x2
Discussion in 'The Hokey Ass Message Board' started by Blue Moon Garage, Dec 3, 2011.
  1. Blue Moon Garage
    Blue Moon Garage
    on a 283 sbc 4 bbl intake? Any problems, suggestions, etc?
  2. chaddilac
    chaddilac
    I'm about to find out myself!
  3. Hubbcat
    Hubbcat
    from Sweden
    More small are always better then one BIG.
  4. LOWDUG37
    LOWDUG37
    Yes,had his setup on a 283 in my dodge pickup,loved it.
  5. I replaced an Edelbrock 600-cfm 4-barrel on a stock 4-barrel intake'd 331 Chrysler Hemi with a Speedway (Vintage Speed copy) adapter and two Holley 94's straight up (I ran #51 jets in both carbs and 2.5 Powervalves, set both accelerator pumps in the middle position, eliminated one choke and kept the other one in place), and the difference was NIGHT AND DAY!!! The car laid rubber like never before and the throttle response was AMAZING. I honestly expected the opposite results from the swap, but was only after the aesthetic gains, so I was pleasantly surprised.
  6. The Rochesters may be a bit much for a 283 unless it's warmed over a bit, especially with direct linkage. Not sure if that's what you are planning on running or not, but just figured I'd throw it out there. Also, even though the Speedway part is a copy-cat piece, it is drilled for the small pattern early four-barrel flange as well as the larger spread and square-bore flanges, so it's a touch more versatile.
  7. 296 V8
    296 V8
    from Nor~Cal
    Good luck dealing with that guy and his wife
  8. Blue Moon Garage
    Blue Moon Garage
    Hey Chaddilac, keep in touch, we'll share the experience!
  9. shane85
    shane85
    lol i was thinking the same thing.
  10. Blue Moon Garage
    Blue Moon Garage
    :confused: Charlie was very freindly and helpful, no problems whatsoever. Maybe it was you..................
  11. 296 V8
    296 V8
    from Nor~Cal
  12. Buddy Palumbo
    Buddy Palumbo
    Still a cool product
  13. Don's Hot Rods
    Don's Hot Rods
    from florida
    Charlie and his wife have gotten some bad reports at times, but our experiences have always been fine. In fact, I just bought some parts from them at Turkey Run and she gave me a price then a few minutes later gave me a better price without me asking. But that is just my experience with them.
    As for the 2 x 2 setup, yep, I had a 600 Edelbrock on the 350 Vortec in my 23 and it was a sweet running setup. Gas milage was fantastic, smooth response, etc. But it looked lost up there so I bought a 2 x 2 setup from VS that used two Rochesters. I would be lying if I said it ran better because I really believe nothing performs better on the street than a properly tuned single 4 barrel, but the 2 x 2 setup was fine.
    Gas milage was not what I got with the Edelbrock, which surprised me as I ran on a 2 barrel most of the time, and power was down a little. However, they sure looked better up there and changed the complexion of the car altogether.
    I would recommend one.
    Don
    With the old 4 barrel...........
    And with the VS setup..........
  14. Blue Moon Garage
    Blue Moon Garage
    Thank you for the comments and photos, Don. I appreciate some have had problems with their orders but the photos are the setup I already ordered and received in one week's time and I am only interested in problems with installation/operation. Others can save their comments/complaints about service, etc. for another time. Thanks again!
    PS love that new pinstriping on the cowl!
  15. tfeverfred
    tfeverfred
    This could get interesting. I'd looked at that setup too.
  16. heyitsnate
    heyitsnate
    I got one years ago, and the holes didn't line up well but with tweaking it sealed fine, and worked very well with 2 94's on my 327. I forget the specifics but yeah it was worth it.
  17. Koz
    Koz
    I've run this setup on several motors and it works beautifly if.....
    The carbs are jetted right, (obviously!), and since I like the 94's, the power valves are right as well. I always run them with a straight linkage. I've seen them run progressive but they just seem to work better for me straight up. Remember the CFM of those carbs is minimal at best, between 135 and 165 each, so this is not a max performance situation but set up right, gas milage is excellent and throttle response is smooth and even with no stumble. Just don't get discouraged, the first time requires a little dialing in.
  18. Good info and was thinking about one of these set ups as well.
  19. cruzr
    cruzr
    I know its the economical way out , but to me it just doesnt look right..JMHO
  20. Koz
    Koz
    It's not exactly new technology. Edelbrock and others marketed Y type adapters for two carbs for flatties and others very early on. Actually I believe they are making them again.
  21. Blue Moon Garage
    Blue Moon Garage
    Well, the 4 bbl is off and the 2x2 is on for mock up of fuel lines and throttle cables. My existing throttle cable set-up will need much modification but the fuel system is relatively easy.
  22. Don's Hot Rods
    Don's Hot Rods
    from florida
    Looks good. When I first considered buying the one for my 23 I felt it was sort of a cheating way of getting a multicarb look, but after it was on I actually started to like the way it sat up there. It's like everything else, some will like it and some will not, but at the end of the day you have to please yourself and just yourself.
    Your A looks good too. :)
    Don
  23. Don's Hot Rods
    Don's Hot Rods
    from florida
    I don't know if this lousy picture will help you figure out your throttle (and kickdown if you have an automatic trans) but here is what I came up with to mount the linkage on my 23. I had Lokar throttle and kickdown linkage and I needed to make a plate for the chrome lokar mount to go onto, so I fabbed up a flat bracket that I cut from flat stock. I made it so it bolted to the back two carb mounting bolts and it curved slightly back and then over so the Lokar mount could bolt on top of it. It worked fine for the 3 years I had it on there before I sold the car.
    Looks like your coil would have to go, but I mounted mine to the front of the drivers side head and ran the coil wires from the distributor along the intake to it. Just thought this might help you out a little.
    Don
    I found a better picture showing how that bracket was shaped.
    And here is where I moved the coil to.
    If you look at the very top of this picture you can see the mount I made up and how the Lokar bracket bolted to it.
  24. lorodz
    lorodz
    works good i used this set up before ..an his other adapters also nice guy to dal with also.good luck
  25. alex1954chevy
    alex1954chevy
    im interested in running this set up as well. i have a 454 chevy im going to run in my 30 ford. i was wondering if you guys think this set up would work if i got the 3x2 carb set up with holley 94's
  26. damagedduck
    damagedduck
    from Greeley Co
    WOW..how did i miss this tread?? i bought 2X2 adapter from a gentle man from here & plan on running it on my 225-6 W/ 2 94's,anybody running one of them? if so can i see your linkages?
    any tips & trick would help too!
  27. 69fury
    69fury
    from Topeka
    Blue Moon: that looks great-you going to leave the frog mouths red?
    Maybe match the throats to the body color, with an inner pinstripe of the fender color?
    -rick
  28. Blue Moon Garage
    Blue Moon Garage
    Finally did the installation yesterday and today and took a 5 mile test run. Ran great but bogged when I put my foot to it so some adjustments are in order but IT LOOKS *****IN' and otherwise runs GREAT!!! Started easily after fuel reached the carbs, adjusted the idle and off we went. Thanks to those who contributed information.
  29. Blue Moon Garage
    Blue Moon Garage
    So, what do you think?
  30. damagedduck
    damagedduck
    from Greeley Co
    HELL YEAH!!!!:cool:
