I realize Vortec heads are far from traditional, but if the hood is closed, who will know? I need to modify my Vortec heads so I can run a high lift cam. Don't want to spend $150 on tools I will only use once. But I would be willing to pay rental fee and a deposit if someone will loan them to me. I need: Comp Cams 4718 Comp Cams 4726 Comp Cams 4732
Can't go over .450 lift. Beehive springs are $200, plus the valve keeper will still bottom out on the guides.
aw if you were only closer i'd just cut -m- 4-u- free... What does your local Machine shop charge? can't be more than 160.00? cut guides down to fit .501/.530 seals far enough down for .500+ lift cam.... cut spring seats out to 1.440 ...
a suggestion buy them 150.00 put em on ebay at 1/2 your cost... they'll sell edit--> (i just checked ebay quickly, and none used) and or look on ebay for used ones so your rent/one time use ed only be or cost cha 75bucks... ta get the job done...
