Anyone here bolt on a T-5 trans behind a 283 small block???
Discussion in 'The Hokey Ass Message Board' started by Deuces, Aug 19, 2011.
  1. Deuces
    Deuces
    With a 3.35 first gear ratio... How does the low end torque feel???
    Let's hear about it!!...
  2. badshifter
    badshifter
    Did you put 283 and torque into the same question? Ha! I did a 265/T-5 with 3.5 first gear and a 4.10 rear gear. Light car, scoots right along. Not gonna win any tractor pull contests but it is fun.
  3. Mattilac
    Mattilac
    I run a 3.00 rear end with that first gear. Works out well, but then overdrive is too high :eek: I etched a 'B' on the knob for 'Bonneville'
  4. Deuces
    Deuces
    I should have mentioned with a 3.55 or 3.73 rear gear ratio.. My bad!.. :eek:
  5. badshifter
    badshifter
    Well in that case, if we have a tractor pull contest, I'll win!
    Rear tires are 29.5" tall bias plies.
    Seems like 5th (o/d) ends up being a little to tall for low HP engines with a higher rear gear. I'd go 3.75 or lower. Put a quickie in it and then you have lots of choices.
    I know, not what you asked. But.....
  6. OCIE
    OCIE
    from TRINITY,TX
    I've got a t5 with the same 1st gear. Planning on putting a 4.10 rear gear in it. I currently have a 327 muncie 4 speed 2.56 1st gear 3.70 rear gear and 30" tires. It's alot of fun but it could use more low end. I have a friend with the same 5 speed and a 4.10 gear and he loves it.
  7. CB_Chief
    CB_Chief
    from Oklahoma
    I have a T-5 in front of 3.73 gears running 275-60-15s and the truck is not bad, not a torque monster but it drives good. I am thinking about going to 3.90 gears to raise my rpms at highway speeds, currently it runs about 1950 at 70 mph. I have a 283 (.040 overbored) with 270H Comp cam, powerpack heads, Performer intake w/ EDL 1405 (600cfm) carb and blackjack shorty headers. It gets about 20 mpg highway but I have to drop to 4th on all but very slight grades. The transmission gear set is from a IROC Z Camaro.
  8. vrod64
    vrod64
    from Katy,Texas
    Should be great ! It will probable fall on its face in 5th.
    Also that ****** uses "Atomatic transmission oil". Not gear oil.
    FTI
  9. cooljralan
    cooljralan
    from nc
    i have basic same motor in my 53 5 window. 283 with s10 t5, 3:42 gears. love it.
